Propane cylinder storage?
No thanks man. I hate the smell.
So much so that when somebody is purging a fresh tank at work, I find myself taking an early lunch just to get away from it. And I work INSIDE. :snorkel:
how are you re-filling the tanks? Are you using the adapter they sell at harbour freight and tool?
Thats the one.
Thats not all that is needed though. You will have to find yourself, or fabricate yourself a bleed valve tool. I made one using an old screw driver. Cut the tip off, ground the diameter down just enough to fit into the tank, then cut a slit in the end to turn the bleed valve.
The bleed valves are very small, and the tool has to be JUST right to work.
Just being around me would probably make you sick. I'm sure the smell clings to me all the time. I wouldn't know though. I can't smell it.
Mr. Heater Brass Propane Tank Caps. $6 from Cabela's.
29xvzsFHC_acWIG0hIoL0AsD0sCpMk1Qk6pO0YaFdvaAz4fOv98G6Y5X0AlE9znwj0QGkxdHPXHgVtjwPf4eEN4selsAda1_h3p7cqwuuzH8zUiZUm0PEQ0s9LqjFEDpFNyNNnvA9BTRO6QASeQFKAI2ZpxHK4ziiGWBl2Qa9u5Toe1ktZSl_KA7dxs_yfvCrw
LukeSkywalker515
