Martinjmpr
Wiffleball Batter
We got our Camp Chef Teton stove in 2012 and it has seen hard service over the past 5 camping seasons. Recently it has started leaking gas from the regulator. We are hoping the only issue is the regulator itself (a replaceable part) rather than the stove. The symptoms are the smell of gas even when the burners are not turned on and - more alarmingly - when we use the burner closest to where the regulator screws into the stove, there is sometimes a small flame that develops at the point where the regulator connects to the stove (for this reason we now only use the burner that is farthest away from the regulator on the left side of the stove.)
I think I may be able to order a replacement regulator from Camp Chef for about $20 but I also see one on Amazon for a Coleman propane stove.
https://www.amazon.com/Coleman-Stov...8&sr=8-4&keywords=gas+camping+stove+regulator
Since I assume all these stoves are probably made in the same Chinese factory, it would be reasonable to think that the regulator is the same as well. Does anyone know if this is the case? It certainly looks as though it is.
Even though the price difference is only $4 the advantage of using a Coleman product is that I could get one locally - not sure if my local camping stores would stock a part for a Camp Chef.
And the second question (which I suppose should have been first), has anyone else had this problem and if you did, was it, in fact, the regulator? I'd hate to spend the money on a new regulator and find out that the problem is not the regulator but the part that the regulator attaches to. If that were the case I'm assuming that I'd likely need a new stove as I don't think that part is accessible without disassembling the stove and even then it might not be cost effective to replace.
Thanks in advance. :ylsmoke:
