Purchasing Chaser Fenders
Martyn
We get a steady stream of inquires from people wishing to purchase our Chaser fenders. They are 12" wide and big enough to accommodate 37" or 38" tires.
The fenders are made out of 14 gauge zinc washed steel and they are powder coated black.
Cost on the fenders are $100.00 each plus S&H. They are expensive items and it's one of the reasons we haven't kept extras in stock.
We would need to have a batch of 10 fenders manufactured to make this work.
If you would like a set for your trailer build please e mail us at info-at-adventuretrailers.com
The fenders are:
12" wide
12" top to bottom
26" top surface
36" lower edge to lower edge
SAR_Squid79 said:
Any updates on the availability of these fenders? I still need a set!
We have not place a new order for Chasers, and we didn't have enough interest to make it cost effective to do a separate run of fenders. We are looking into making some in house out of composite.
Alright, let's try to get this going! I just got the green light and greenbacks to build the trailer I want. I'll take a set, also. Come on people! I like the metal, I like the ability of it, that it can support a tabletop.
You know you want a set, people!
Martyn, do you mind if I cross post this on IH8mud also, to see if we can get the interest up?
No problem cross posting.
We are getting quotes on aluminum and steel fenders in low volumes. The numbers as still coming in.
With powder coat minimum charges at $150.00 and set up costs for the fenders it's making sense to try and get 10 sets.
Chaser Fenders $80.00 each F.O.B. Upland CA.
14 gauge steel, bare metal.
We need 5 pairs to make the order work.
Powder coating in black is possible but it would be an up charge and we would either need to send it in with other product or all of the fenders would need to be powder coated to avoid the minimum charge of $150.00
For an order form contact me at info-at-adventuretrailers-dot-com
Martyn
Martyn
Put me down for a set Martyn. Will give you a call. Hopefully powdercoated.
Thanks
Fj89
