Question for the electrical guru's (Horn and keyless prob)
saburai
Hi Gang,
I Posted this on NAXJA to no avail...
My horn and the key fob unlock function (lock is O.K.)quit at the same time. Keyless receiver is getting signal as the interior lights go on when the unlock button is depressed. Door mounted central locking seemed fine but the power unlock function is not working properly. when the switch on door panel is activated the solenoids kick, but the doors do not unlock. Horn relay is working, both when I press the horn pad and the panic button on the key fob. All fuses are good.
Can you please tell me what wire/connector/circuit to look at?
Many thanks!
clearwater
