The basic plan of the floor is a 2x3 steel frame. The area of the floor that is walkable, plus the head, will be framed with a 2" height leaving a void of 1". That 1" will have 1/4" plywood on top of the floor framing with hot water tubing on top of the plywood. (the walking area will have 2" of rigid urethane under the 1/4" ply, the rest will be 3") The whole base of the cabin will then be decked with plywood.
It seems that the heat would be more even if there was some kind of heat sink in the void with the tubing. The thing that immediately comes to mind is sand, but that would be approximately 160 pounds of unwanted weight. Any ideas? I am open to advice about floor heat and the whole plumbing scheme in general. I plan to use a water heater/heat exchanger augmented with an Espar. I'll post my plumbing diagram later. I think I have come up with a workable plan, but I'm no expert. This is all one big experiment.
Earl
Earl
