Real world experience with James Baroud awnings
Nathansharkey80
Hey there
Just wondering if anyone has ever tried out the falcon tunnel awning by james baroud. Any thoughts about it that you can share?
Sent from my SM-N950F using Tapatalk
I have the 2.0m awning with tunnel, and a Grand Raid XXL tent. Also the room enclosure. Overall, my family has been happy with this setup.
We have had a few “learnings” along the way:
Several times we’ve had the awning poles stuck in deployed position and couldn’t get them collapsed. This may be us overtightening vs. a product issue... but I fixed this permanently by staking the plastic cam fitting into the aluminum pole with a punch, no issues since then.
The awning rooms walls are not tall enough to reach the ground on my truck, they come up several inches short. It really isn’t a problem since the room is not fully enclosed and thus not weatherproof to start with. I imagine our truck on 37s with the awning mounted inline with the top of the cab is generally on the taller side of most setups.
The tunnel opening can be a little tight depending on how your awning is located vs. the tent, as well as your physical body size. It doesn’t render it unusable, but I generally end up rubbing my back on the tunnel/awning edge interface climbing in or out.
We also had an issue with our tent itself leaking due to a bad fan/shell seal - but we received a new tent for warranty replacement that had been flawless, so no customer service complaints.
Would I do it all again for ~$6100 new? Yes and no. After 2 years and 50ish camping nights, everything is still working and holding up well. However, the tent is getting tight for the 3 of us (7YO, wife, myself) and we likely will have to do something different for a tent next year... which also likely means changing out the awning/tunnel/room setup as well, which is a lot of work/effort on top of the cost.
1reddog48
