Just wanted to add to the knowledge base.
I found these hubs on a Gen 1 short wheelbase Montero in the junkyard, cleaned them up and they fit perfectly on my Gen 2.5.
This paint closely matched the original gray color (Dark Machine Gray 7587).
Very lighted coated the internals with this after cleaning out the old grease.
I picked up 2 of each of the following at the Toyota dealership:
O-ring (fits around locking hub dial)--part# 43532-60010
Hub gasket (round, fits between locking hub body and wheel hub)--part# 43531-60010
Spindle gasket (star shaped, fits between locking hub body and locking hub cover)--part# 43422-60020
Torque Specs (per 1987 Montero FSM):
Locking hub body to wheel hub: 36-43 ft-lbs.
Locking hub cover to locking hub body: 7-10 ft-lbs.
www.wabfab.org also sells gaskets and small parts for rebuilding Aisin hubs.
Hope this helps someone.
