Recommendations on best 'expedition' tire?
dieselcruiserhead
16 Years on ExPo. Whoa!!
Did a brief search and couldn't find anything on it. I have run MTR's before and they are great and have incredible traction but their soft compound ie road wear and high road noise leave little to be desired IMO... I am thinking of going back to a BFG MT.. I like AT's and think these would be a great tire too but am wondering what people's thoughts are for off road, at the MT's really that much more superior? I guess they probably are after being stuck in the mud several times and having a heck of a time getting even the MTRs to self clean... But I rarely do mud, mostly southwest desert and rock? Also load carrying ability? I have been a 15" guy mostly in the past but will now be using 17" rims for this new rig to get ideal backspacing and width. I will be running a 7.5" wide rim which is a tad narrow but the best I can do looks like with my approx budget for wheels (less than $300 shipped and I prefer steel). Beauty of the 35 x 17 is load carring ability, it goes upto D from C and can be inflated to 50 psi. Also weight goes from 2300 to 3000 lbs per wheel. But that said even my 35 x 15's still carried a load very very well, surprizingly well... But 32 psi on my 35's was dangerous, it wanted to slip out particularly in bad weather. I wonder if it will have the same effect with the 17" rims...
I am also considering Cooper discovery which is also a harder compound for better wear and significantly quieter as well than the MTR's....
The BFGoodrich AT KO might be your best overall choice. 315/70 R17
The Toyo Open Country is a nice tire as well, and is available in the size you are looking for.
I am also looking at a more highway / Ice / Snow friendly tire too.
I have been really impressed with the Nitto Terra Grapplers that I put on my 80. I'm sure that I'll take that statement back the first time I end up in any mud, but on snow, sand, moab rocks, and loose dirt they have been amazing, I might say even better than the BFG MT's on my 60. Time will tell if the sidewalls are up to the task but I have pinched them pretty well with no problems yet.
I was pretty nervous putting on tires that are more frequently seen rolling on chrome 20's as opposed to a trail truck but I have not regretted the decision.
BTW, I'm running 295/75 16's
yes same here, with both the Nittos and the Toyos, most guys around here that have Toyos on big retard jacked pickups, sort of the cool it thing to have or something like that. Puts a bad taste in my mouth about them a little bit. But they do make a 35 x 17. Same with cooper who actually makes a small 315 75 R 17 which measures to about 34" then there is BFG and MTR again... :)
I love my AT's, my Tacoma is on the 3rd set, and I will put another set on it in a heartbeat. That thing has been in every corner of the state on trails up to a 4+ without a single problem (knock on wood). I have also been known to carry alot of weight (8 axles from Cali ;))
But, I love the MTR's too... tire noise is a downfall, but you'll get the same out of just about any aggressive MT. The MTR's in my Cruiser have also been all over the state, and they have lasted surprisingly well for a rig that really only sees the street to and from the trails and ~5000 miles a year. You would probably be better of with an AT unless you actually plan to more dedicated wheeling in your next Cruiser than the last... DD'ing will kill MTR's in a hurry on a heavy rig. I bet I only get 15k out of my MTR's... but they get beat on pretty good. Still wouldn't second guess buying them again.
I'm not sure I can make a good recommendation for an expedition tire because it all depends on the overall conditions expected during the trip. Overall, I do agree that you want a strong tire with a relatively hard compound, very strong sidewalls and good load rating. There are several Michelin tires that fit that bill, but they're relatively hard to find in the US and expensive when you can.
I will tell you one thing; if you're building a dedicated expedition rig and plan to cross borders with it, 17" rims is *NOT* a good size. Yes, you'll get better handling on the road, but finding a 17" tire in remote areas will NOT be easy and in other countries, you can forget about it. They may be all the rage these days and come OEM with many different vehicles, but they're still very rare elsewhere. I'd stick to 15" or 16", the latter for a better load rating and better handling.
Gotta say the 760R16 Michelin XZL is one heck of an expedition tire. But expensive and hard to find these days.
cheers
Graham,
What were your overall impressions of the tire? You are one of the few that has actually spent time with them.
I noticed that you ran split rims with them too. Are they not a radial tire?
Scott,
The tire is pretty awesome. Not loud on the road, works great in sand and mud and is really tough! Little crazy on wet asphalt though! It is a radial tire and I didn't run it on split rims. Those are Wolf wheels, 1/4" steel and *heavy*! We had a lot of flats on the trip, but that was not due to the XZLs. I went with tubes, and unfortunately the tubes that Big O sold me were really crap! A guy in England tried to warn me off them, but I was feeling poor and off we went to Africa. At low tire pressures the tubes would rupture from the heat, and this is driving at no more than 35mph! Once we got a few flats, it was just a matter of the tubes continually coming apart. We never got a true puncture in the tire, but lots and lots of holes in the tubes. In Gabon I was able to source some Michelin tubes, and those worked much better. It is pretty cool that you can run the XZLs tubless or with tubes, but if you run tubes, get Michelin ones. Nothing else will do!
cheers
Only benefit is ease of getting the tire back onto the bead if it comes off. Didn't have enough air pressure from the compressor to do it, so went tubed. I have since learned tricks for getting a tubeless tire onto the bead, so I think I'll skip the tubes next time. I'll just carry a couple of tubes just in case my tricks don't work.
In terms of drivability, the XZL is great. Being tall and skinny it gives a nice low pressure contact patch, so works very well in soft sand. The compound is pretty hard, so you don't get the grip rockcrawling that you do with, say an MTR, but in mud it crears the lugs really well and gives good traction. Sidewalls are plenty tough! It was a real fight to get the tires off the rims with my tire irons!
cheers
A little late to the thread here, let me chime in with a product that has served me extraordinarily well over the years. It is the BigO XT. It's kind of a cross between an AT and MT. Anyway, I can't say I'm a fan of the BigO comporate entity especially its sales folks, in fact quite the opposite, but I have had amazing luck with this product.
It is studdable, without siping performs amazing in snow & ice, and has taken a serious beating by countless offroad trips. The last pair of XTs I had for 6 years and about 60k miles, and still a lot of lug left and are on my 40 series now. I have heard folks really badmouth these tires because of the sidewall, but I'm the only one I know that has ever run them; I never had a puncture and those tires ate many hundreds of miles of rock on their sides, not once in 60k miles had a flat or even a small leak? Lucky? Maybe.
I bought them because by default the XT is a free fix & replacement for the life of the tire, yet never had to employ it.
Anyway, I am now on my second set with only 3k miles in. If you can find a decent store, I by all means recommend you at least take a look at them.
Another tire that I don't think you can beat for your $ is the Dunlop Mud Rover:
i'll throw in a belated "me three" for the BFG AT KO. i ran some big o tires earlier, and they didn't hold up to my satisfaction, and as my interest in wheeling grew i moved into the BFG and have been quite satisfied. i was pleased that the warned-about hydroplaning simply did not occur in any way when i drove through a torrential downpour. be sure to rotate frequently and keep your rig aligned, or you'll really wear 'em down. the compound is fairly soft, but it's oh-so-grippy.
i suspect that nearly everyone is happy with the AT or MT they have, so it may be difficult to really get an objective look at the various models. i don't see consumer reports doing an offroad test anytime soon :smilies27
Tire Recommendation: Yokohama
OK, so I'm a bit late to this party, but we have stock Yokohama Y742S. These babies are just 10 ply but after driving 38K hard miles across Central and South America we have had only one flat and that was caused by a nail. They are not fancy but if you want something that will hold up, they have my recommendation.
Late as well! I was really surprised to see the Dunlop Mud Rover listed. It is often overlooked. I must say that these have been a great tire. I have wheeled with several other jeepers and must say that these tires outperformed the following tires in a side by side(apples to apples) comparison:
Goodyear MTRs: Easily ate these for lunch
Nitto Grapplers: Took his lunch money
Big O XTs: another easy take down
I got a set of 315/75/16s for under $140 each. Not bad and I would HIGHLY recommend them.
Bobbyjr
