$14k. Used about 14 nights and has under 5000 miles total. Trailer has always been stored with Damprid for humidity control; it’s always been perfectly bone dry inside. Ceramic coated between washes. Located near San Francisco International Airport. As spec’d out from the factory, with shipping on a flat bed this would cost $19k. Happy to answer any questions you have.
2021 Weeroll Wrangler-X. The box is 5x8x4’, with 7’ axle track width. Factory powder coating, roof racks, blackout package, and 31” offroad tires.
- Weighed 870lb from the factory, now weighs about 1100lb. It can be towed by just about any vehicle.
- Registered and plated in FL as that is my state of residency. You will have no problems registering it in CA. I’m located near San Francisco.
- 100% 6061 T6 aluminum construction. No wood and no steel. The roof is a 1 piece pressed sheet of thick .090” aluminum that runs the full length of the trailer, and down the nose to the frame with a built in drip edge. Lifetime leak proof roof warranty from Weeroll. The exterior is 3M industrial bonded .068” aluminum, the interior walls are .040”. The walls are 1” thick with insulation.
- The main frame and tongue are 1/4” thick. The main frame is built with 2x3” tube and the wall & roof frames are built with 1x2” tube. This is the last year that Weeroll built their trailers with square tube main chassis and triple tongue before moving to C-channel construction. Both are plenty strong, but tube chassis is somewhat stronger.
- Dexter Torflex 2500lb axle. Hubs re-greased 1000 miles ago with “Red N Tacky”. The axle is tracked out super wide making the trailer extremely stable on and offroad.
- Driver and passenger side doors, and double rear 50/50 barn doors, all are built heavy duty by hand with 1/4” square tube, and double weather stripped. Each door has a rain rail below the roof drip edge.
- 20x15 sliding side windows with privacy glass and screens.
- Front removable portal for a fan, AC, or heater.
- Full size memory foam mattress on lightweight platform frame.
- Rubber protective flooring over 1/8” aluminum solid smooth plate floor.
- Renogy 100w solar panel and 100a AGM deep cycle battery. The combo puts out more power than the trailer really needs. It can run a DC fridge and all of your accessories indefinitely.
- 30a external shore power AC receptacle. Interior AC/DC outlets.
- Roadshower/Yakima 4.5 gallon aluminum solar shower.
- Wheels are Jeep lug pattern from the factory but can be adapted to Toyota.
- Never mounted full size spare wheel with new tire included.
- Extra 1/4” aluminum axle hangars included from the factory for any future modifications, such as Timbren axles.
- Rear stabilizer jacks.
- Lock N Roll hitch, always greased. Including both the trailer and vehicle sides of the hitch with the sale.
