Rock Slider Catalogue
HongerVenture
This thead is to catalogue the various, aftermarket ROCK SLIDERS that the Expo community has.
Posts in this thread should indicate the following:
Vehicle: Year, make, model
Slider Manufacturer: ARB, TJM, custom-fab, etc.
Associated Accessories: Mudflaps, diamond plate, etc.
Mounting: Bolt-on or weld-on
Other Notes: Interesting items of note
Picture: Attach or link to a picture
Please try to keep posts relevant and on-topic to make this a handy tool for the forum.
Vehicle: 1975 Toyota Landcruiser FJ40
Slider Manufacturer: Home built
Associated Accessories: N/A
Mounting: Bolt-on
Other Notes: Bolts straight to the rocker. Fabbed from 1/4"X3"X3" Angle cost w/ hardware ~$40
Vehicle: 2004 Toyota Tacoma DC
Manufacturer: Rafferty
Mounting: Weld on
DeMello Off-Road Bolt On Hybrid Sliders
Vehicle: 2001, Toyota Tacoma DC
Slider Manufacturer: DeMello Off-Road
Mounting: Bolt-on Hybrid
Other Notes: Takes a beating! Sorry Old pics...
Pictures:
These are DIY sliders, but an option
Vehicle: 1999, Toyota Tacoma
Slider Manufacturer: Built in my garage!
Mounting: Bolt-on
Other Notes:
materials
2 x 2 x 3/16 main tubes
1 1/2 x 1 1/2 x 3/16 legs
1 1/2 SCH 40 pipe outer tube
1/4 mounting brackets
Way too heavy, but the price is right!
Here are some pics of my DIY sliders:
Side view:
Mounting points:
Front Cross member mounting bracket detail:
Front Cross member mounting bracket backing plates and bolts:
Top left bolt is 3/8" bottom is 1/2" all hardware is Gr 8.
U shapped bracket and gussets:
Bracket is 3" wide by 5 1/4" tall. Gussets are 4" x 4" x 5.5".
Back side of U shapped bracket (it's about 1/4" to 3/8" short but it works):
Finally this pic shows the location of my BudBuilt bolt in cross member for my belly pan and the location of the U shapped bracket. I would guess that the newly re-designed Demello Bolt on sliders would fit witout interferance as well. You can also see in the pic that the brake lines had to be spaced away to make room for the U bracket. I just made up a spacer that goes under the bolt for the brake line holder (top left hand corner of pic).
Cheer :beer:,
P
Vehicle: 1984 Jeep Scrambler
Slider Manufacturer: Sun Performance
Associated Accessories: When you cutout for TJ flares, the CJ7 sliders fit perfectly between the flares on a Scrambler.
Mounting: Bolt-on
Other Notes: I'm very happy with them... They earned my respect after falling into the firehole on upper woodpecker.
Vehicle: 1987 Toyota Standard Cab
Slider Manufacturer: All Pro Off Road
Associated Accessories: Also serve as mounting for cage work
Mounting: weld-on
Shrockworks stuff is amazing. A lot of my Xterra owning buddies use their armor. I tried to get them to make stuff for the Pathfinders, but nobody local to them wanted to let them use their truck...:mad:
Vehicle: 1993 Toyota FZJ80 Land Cruiser
Slider Manufacturer: Hanna Quality
Associated Accessories: I put a little grip tape on them
Mounting: Bolt-on
Other Notes: I love them!! Beautiful workmanship and strong as heck.
Front Passenger mount with cat protection uses factory holes for the transfer case crossmember.
All the other mounts are like this.
They are strong as can be.
They look great with the flares and splash guards.
Or without.
Dave
Stubs Welding Standard Sliders (weld on) -
Stubbs Welding SKO-HD Sliders (weld on) -
Vehicle: 2000 Toyota 4runner
Slider Manufacturer: Stubbs Welding
Associated Accessories: Bud-Bilt Skid and Shrockworks bumper
Mounting: Weld-on
Revenge Fabrication
Vehicle: 1998 Toyota Tacoma Extracab
Slider Mfr: Revenge-Fab.com
Associated accessories: CBI Fab bolt-on brackets.
Construction notes: Constructed from 1 3/4 .120 wall HREW, 4 mounting legs. DOM sliders custom made to order
Mounting: While these are sold as 'weld-on', I opted to go with CBI Fab brackets and bolt them on.
A little wide for some, but they double as a nice step for ingress/egress from the truck.
Dynamo TCX
