Roof Rack with retractable lights and kayak rack
Curtis in Texas
My Rodeo Roof Rack
I was asked by some others to post up some info and pictures of my roof rack with folding light bar and folding kayak carrier. So here you go, maybe this will give you some ideas on how to make yours more garage friendly for you. Some of this I bought and some of it I made. It wasn’t that expensive considering!
Carrying capacity is somewhere in the 1000lb range, but I would hate to drive around it with it loaded with that much on it. The Yakama Cross bars are rated at 250 lbs each and there are 4 cross wise and two length wise.
Sorry, but these were taken in my shop today as it’s very cold here in Texas today.
This rack has served us well for several years so you’ll notice that there is some rust and wear and tear on it in these pictures. And yes, this truck does fit inside a standard garage with a roll up door. But not like this.
It all folds down like this in seconds. Once you unload the roof rack of course!
Here’s how I manage to fold it down.
The first cross tube is a standard size Yakama Cross bar but the kayak and light bars are slightly bigger diameter, but they are shorter lengths and slip over the cross bar. The light bar is the longer of the two with the light mounting tabs welded to it and the kayak bar has two tubes that fit outside the light bar part.
I cross drilled the pin holes for the detent pins used to hold the kayak rack and light bar in the up or down position. The Detent Pins are Aircraft Grade quality and have never given me a minute’s problem. If you’ll notice the wind deflector and side rack strut are bolted together. These do not rotate with the other LB & Kayak tubes. They locate the rotating pins and keep them on alignment with the holes.
This is the locating pin for the light bar. Lift it up and the light bar can be laid back or raised. It locks in the down position to prevent it hitting the roof.
I made this piece out of a bolt with a Yakama plastic bolt head, one washer, a small compression spring and a short piece of square tubing and a drive pin through the bolt. Stuff I had laying around in my junk drawer.
Let’s talk about the air deflector.
The wind deflector is nothing more than a piece of aluminum from a cabinet door.
It’s held in place with the two straps you saw previously and two springs to keep them against the truck body so they don’t bounce. Here’s the retention springs. You can see the bottom lip is padded with a piece of split hose to keep the damage to the roof down. It works great and doesn’t break in cold weather like the plastic ones sold by the big named Companies.
Curtis in Texas
Part 2
Here you can see a shot of the Kayak rack laid down, notice how it fits in front of the top basket.
And here it is with the light bar laid down too.
The rear kayak rack is done the same way as the front with the detent pins.
It lays back and does not hit or interfere with the rear glass, radio antennas, or bike racks. In fact everything is made to function with any or all features in use.
You can see the top basket in this picture and the Mountain bike racks.
The bike racks are Yakama units I had from my cycling days. I have a lot of bicycle mounts from back then. But, let me tell you about the Top Basket.
I found that basket in the dumpster behind a Virgin Records Store. Some of the welds had failed so they threw it out. I don’t have a habit of dumpster diving, I was taking a short cut behind the store and caught this out of the corner of my eye. Turns out it is a bargain rack for old CD’s. I modded it a little with some floor braces as it used a piece of particle board in the store. It even has a mount for my flag pole to go. It measures 46” X 29” and is strong enough it can carry 400 lbs without bending. It’s carried 4- 5 gallon metal military gas cans and 3- 6 gallon plastic water jugs. What a deal.
No doubt you’ve noticed by now the shovel and axe mounts.
I found a company in Montana called Wilderness Outdoor Products that make these very rugged rifle mounts for carrying hunting rifles in your vehicle or on your ATV. These things are the toughest I have ever found. I like them because you can separate them and make them carry almost anything. I even use them inside my Rodeo to carry binoculars, rifles and fishing poles.) There are even a set inside my Motorhome to hold my hunting rifles while traveling in the U.S...
The axe is mounted on the drivers’ side, because of its potential for doing a lot of damage by unauthorized persons; I want it where I can keep tabs on it.
I made the blade guard to keep the danger level down as I like a sharp axe.
So here is the guard and how it’s held in place.
And here is the shovel mount.
These rifle mounts are mounted to the ends of the #2 and #3 Yakama cross bars.
There are 4 cross bars on this rack system.
Here is the front view in the down position.
Woops, looks like the two post lift, behind the truck, got in the picture.
So you’ll have to ignore the blue post.
We were talking once on another thread about wiring lights and I wanted to show the lights on the rear and explain their use.
WE flat tow the Rodeo a lot behind the Motorhome. So the tail lights on the back of the rack are for stop and turn signals when towed. The trucks lights work in towed mode too if the air brakes are hooked up in the Rodeo.
The white flood lights are wired by relay into the back up lights on the truck and there is a switch just inside the tailgate to turn them on for road side repairs or camping. They have saved the day more than once.
I can’t seem to find my pictures of the Rodeo roof rack loaded down with camping gear, Jocassee Kayak, and two mountain bikes. When I figure out what I did with it I’ll add it for you. It really does do it all.
I love my Isuzu Rodeo, it has been extensively modified!
It can go anywhere with 20 forward and 4 reverses. SAS and ARB’s in both ends.
Here I am playing in Moab Utah a few years back with it.
Hope this gives you guys some ideas!
Curtis in Texas
Nice... You've given me some ideas for my future lightbar. I have to be able to drop it so I can get my canoe up there.
Oh, and an Isuzu Rodeo? haha! Wow! It's always good to see folks who aren't afraid to go outside the box. Well done!
jesus m anderson
