Ghillie_Ohio
What is needed to mount a Roof top tent for up to 4 adults ? Do i need a Baja rack in addition to two thule rack ?
I would say the majority of time i would sleep in a roof top tent via a custom rack for the truck bed .
I thought the viperlift required a full size truck. Isn't it too wide for a Tacoma? IMO, you will have a difficult time mounting a tent on the roof. I have a BajaRack on my DC and when I load it with camping gear (maybe 150 lbs +-) I can already see some deflection in the roof at the mounting points. Your average RTT is 100+ lbs empty so you'll quickly exceed the weight capacity of the stock mounting points. A Thule or one of the fixed position variants is the best solution but that will negate the viperlift (which may be a moot point anyway since it may not work on the narrower truck).
Factory rail mounts . So it doable ?
