RTT Tent cover deterioration
gpwpat
I have a EEZI awn that is just over a year old. Just this past summer the cover has taken considerable deterioration. I am sure with the right precautions I can get it to last another couple of years. but the buckles and straps on it have completely rotted off.
Does anybody have any hints tips, products that could be applied to help the cover last longer? I was under teh asumption that they would have been made out of uv protected materials. But I was wrong. The cover probbably has 4 months of sun exposure when it is being used. The rest of the time I tarp up my trailer.
FlyingWen
We live in AZ and the hot summer sun cause our tie downs on the cover to break. I have spoken with Paul May of Equipt, he is the US importer, and he has already notified Eezi-Awn of this problem and Eezi-Awn has been using UV protected fabric to rectify this issue. He has new tent covers in stock and more on the way.
Until we get around to getting a new cover, Wil fashioned his own securing system by using racket tie down straps. It is a cheaper alternative to get you through in the meantime.
I will be adding the tent covers to our site within the next few days should you decide you need to purchase a new one. I would suggest contacting the company you purchased it from to see if that is a warranty issue.
blupaddler
Conspirator
I have the same problem with mine. At this point I have two straps that have rotted and broke. The very top of the cover is also starting to deteriorate to the point where you can see the threads. I have also noticed some water damage to the plywood where it appears I may have a leak.
I need to go out and buy a cover for my tent I guess...
FlyingWen
EDIT: Edited By FlyingWil since I did this...
Below you can see the results of my efforts. The front straps were severly damaged by the UV rays and ripped off. To repeat what they did in the factory I used some tie down extensions, and cut them to length, and used a 12g wire to secure them in the channel as shown below:
This allows for the hooks of the ratchet straps to hook onto. The center of the cover is where the OE strap is sewn to the cover, I removed that seam and used a large stick to replace the OE strap with the ratchet strap. This was the biggest pain.
In the rear I did the same as the front, however I should have made the extension straps a lot shorter... the way it sits now the ratchet mechanism would be on top, and cause issues to the cover, so I am taking the straps right down to the load bars, and hooking to the load bars.
All and all this is much easier than the OE straps IMO, and works very well. If you do this just make sure not to over tighten the straps.
flyingwil
Ok I just abused my mod power and edited FlyingWen's post above. LOL.
I should be speaking with an Eezi-Awn rep about this at Sema, but those with issues if you could please e-mail me pics so I have some ammo to give to Eezi-awn it would be great... my e-mail is wil at sierraexpeditions dot com. (note the one "L")
Thanks guys!
gpwpat
I purchased my tent from Sierra Expeditions. I can dig out the reciept if needed. It is a series 3 1800
I will send pictures today of both the cover checking and the strap deterioration. Again it has 4 months total of sun exposure in the little over a year that I have owned it. I have cheap straps that I also use on my rig that have not even rotted yet and have the same exposure.
I don't mind upgrading my straps. I just wish they were not sewn into the top so they could be easly replaced. The checking concerns me a bit more than the straps. as this is the weather barrier on the tent to keep the tent in good condition while traveling.
here is a picture of the strap and you can see some of the checking. I have more detailed larger images if needed.
here is a close up of the checking on the vinyl. This concerns me more than the strap.
xcmountain80
When it comes time for replacement do it before the top is toast. I took mine to a local boat canves guy and had it made out of UV proof material, it was very similar to the material used by Hannibal when my tent was 1st made. It ran me $110. I had that done almost 2 years ago and it is still in good shape.
Aaron
Equipt
Supporting Sponsor Presenting Sponsor of Overland
Hello All,
I'm not on here as much as I should, so I would like to thank Wen from Sierra Expeditions for alerting me as to this thread. This is similar to a thread posted earlier this season regarding a similar concern.
Since our first concerns were reveiled last year, Eezi Awn has made several modifications to the construction of their covers. They have increased the thickness of the material used in the covers. That increase moved the material into a fabric with 2 finished sides, and a more pliable feel. It "feels" lighter because of the pliability, but will withstand the elements much better. It is the thickest RTT cover on the market. They have been using the same strapping on the tents for some time, and have only had a handful of strap issues. Mostly from the US, and the southwest in particular. I would agree, the sun here is unlike anywhere else. Eezi Awn has adjusted the strapping material they spec as well, to combat the freying issue. Eezi Awn has proven to us that our comment are heard, and that they want to continually improve their offering.
This is all fine and dandy for the recent customers. So, what about the concerns of the veteran users? Equipt and Eezi Awn have an open warranty policy with regard to the products we manufacture and import. If there is a concern with regard to the quality and manufacture of the tent, we will make every effort to remedy the concern to the customer's satisfaction. I believe that anyone that has contacted us, or our dealers, will agree we have done our best to make this statement valid.
With that being said, the cover on the tents are designed to take the majority of wear that life throws at the tents. They are the one truely expendable part on the tent, and are expected to be replaced at a varied interval depending on the conditions of use and environment.
So this creates a subjective grey area as to what is reasonable for a covers lifetime. Our goal is to be fair and reasonable with our approach. We take each individual situation as unique and would like to discuss it directly with the customer to find a solution. This could be that we sell you a new cover, or conclude a new cover is warrantied, or something in between. What ever the conclusion is, we want our customers happy.
If you do have a concern with your Eezi Awn product, please contact the dealer you purchased from, or Equipt directly and we will find a way to make it right with you. Wil has mentioned his e-mail above. You can reach me at Paul at Equipt1 dot com.
gpwpat
I just want to say, While my intentions of this posting was to see if there were any hints on getting my old cover to last longer, and some ideas on replacing the straps. In the End Sierra Expeditions and all involved have taken care of me and my cover woes. While I am preaching to the quior here. but I can't say enough about the customer service that comes from there. I don't know how to express my grattitude more.
In the end my tent and I will keep on traveling. I just hope to find some rain. Can you believe I have been caught in weather while traveling, but never in rain while camped yet. I just want to camp in the rain- now to see how the tent holds up in a down pour. maybe this weekend :safari-rig:
DominicG
I have sun-related problem with my ARB.
The velcro straps have been sun baked and are totally stretched out... basically useless. I now have a system of bungie cords to hold the cover down nice and tight. The bungie cords will eventually get sun baked and stretch out, so i think i'll have to do the ratcheting system from above.
Mp3phelan
