Scan tool gauge
atavuss
saw this on TTORA, anyone using one? looks like a way to be able to monitor vehicle's functions. for instance, I want to add the driver's pillar gauge pod but I want to be able to monitor oil pressure, trans temps, and volts. could monitor volts with the scan tool gauge and do the trans temp and oil pressure with the pillar gauges.
the scan tool gauge is usable with any vehicle that is OBDll compliant (most vehicles after 96). so you could use it in any vehicle to check codes. also it would be super easy to hook up, just plug n play into the OBDll port.
http://ttora.com/forum/showthread.php?t=30474
How super gadget cool is that! I must get one of those :)
being able to read the codes would be a great tool IMO.
Look at all the stuff it does:
SCAN TOOL DIGITAL GAUGES TRIP COMPUTER
Troubleshoot your own car and turn off the
"Check Engine", "Service Engine Soon", or other
warning lamp and clear the trouble warnings.
Reads Trouble Codes
Reads conditions that set the Trouble Code
Clears Trouble Codes
Turns off "Check Engine" light
Make and store up to 10 rewritable special codes
to send to the vehicle computer
Shows 4 gauges at a time from the possible following:
Fuel Economy
Fuel Rate
Battery Voltage
Coolant Temperature
Intake Air Temperature
Engine Speed (RPM)
Vehicle speed (MPH)
Manifold Pressure (not available on some vehicles)
Engine Load
Throttle Position
Ignition Timing
Open/Closed Loop
Automatically tracks three sets of trip data:
Current (short) Trip
Days (total) Trips
Previous Days Trips
Maximum Speed
Average Speed
Maximum Coolant Temperature
Maximum RPM
Driving Time
Driving Distance
Fuel Used
Trip Fuel Economy
Looks like it has some great features, but it sure is ugly!
Too bad I don't need this, or I'd order one!
I agree on the ugly comment and also, how difficult/easy would it be to read while driving down the road.......might have to snag one anyway, says 30 days money back unconditional guarantee on their site
Yeah, but I can think of a bunch of other mods that need to come before I pump $100 into a toy. Ok, it's not a toy, but a cool tool.
I have this scan tool:
http://www.iequus.com/item.asp?cid=7&pid=3110
I picked it up for $150 on sale. It reads the newest CAN protocals also for the newest cars. I have used it several times and it has already paid for itself in savings.
I also have the FSM for my vehicle. Between the two, I can figure out any problem and decide if I should fix it myself or take it to my mechanic.
Anyways... This seems like a decent product for only $110. And it's designed to stay plugged in and provide real time information which is cool.
I think all you guys who said it was ugly are wrong..... It's not ugly, it is FUGLY!!!!!....but, that aside, it is pretty cool, and I can see it being a useful tool. It would just come way down on the mod priority list. Probably the very last item on the list. But still very cool.
Yeah, "fugly" is family friendly :)
That boxy unit doenst bother me too much. I will think it is beautiful when I can read an engine check code!
I don't know if they make it for Toyota's or not, but Auto-tap provides so much information that it is almost overwealming. For example, here is what I can see in the Dodge with autotap:
A/C System Refrigerant Monitoring Status
Auxiliary Input Status
Catalyst Monitoring Status
Comprehensive Component Monitoring Status
ECT
EGR System Monitoring Status
Engine Load
Engine Load
Engine Speed
EVAP Vent Solenoid Command
Evaporative System Monitoring Status
Fuel Pressure
Fuel System Monitoring Status
Fuel System Status Bank 1
Heated Catalyst Monitoring Status
IAT
Ignition Timing
LTFT B1
LTFT B2
MAF
MAP
Misfire Monitoring Status
O2 Sensor - B1S1
O2 Sensor - B1S1 (mV)
O2 Sensor - B1S2
O2 Sensor - B1S2 (mV)
O2 Sensor - B1S3
O2 Sensor - B1S4
O2 Sensor - B2S1
O2 Sensor - B2S2
O2 Sensor - B2S3
O2 Sensor - B2S4
OBD Requirements
Oxygen Sensor Heater Monitoring Status
Oxygen Sensor Monitoring Status
Secondary Air System Monitoring Status
STFT B1
STFT B2
Throttle Position
Vehicle Speed
4WD Mux Switch
InputA/C Pressure
A/C Pressure Sensor
A/C Relay
Actual Gov Pressure
Adaptive Fuel Factor #1
Adaptive Fuel Factor #2
Additive Adaptive Fuel #1
Additive Adaptive Fuel #2
Ambient/Battery Temp
Ambient/battery temp sensor
Backpressure
EGR Solenoid
Baro Read Update
Barometric Pressure
Battery Trim Offset
Battery VoltageBattery/Ambient Temperature
Battery/Ambient Temperature Sensor
Boost Pressure Goal
Brake Fluid Level Switch
Bus Ambient Temp Voltage
Calclulated Load Value
Calpot Adjustmen
tCalpot Multiplier
Camshaft Edge Counter
continued on the next post....
parameter list continued:
Catalyst Temp Sensor
Catalyst Temperature
Charge Temperature Sensor
Charging System Target
Clutch Interlock Switch
Clutch Upstop Switch
CNG Pressure
CNG Pressure Sensor
CNG Temp Sensor
CNG Temperature
Crankshaft Edge Counter
Cylinder #1 Knock Retard
Cylinder #2 Knock Retard
Cylinder #3 Knock Retard
Cylinder #4 Knock Retard
Dis Signal Status
DTC #1 Start/Run Counter
DTC #2 Start/Run Counter
DTC #3 Start/Run Counter
EATXEGR Duty Cycle
EGR Position Sensor
Engine Coolant Temperature
Engine Coolant Temperature Input
Engine Speed
Ethanol Content %
Feedback Factor 1/1Flex Fuel Sensor
Flexible Fuel Sensor
Fuel Control Status #1
Fuel Control Status #2
Fuel Level
Fuel Level Sensor
Gov Pressure Duty-Cycle
IAC Stepper Motor Position
Inlet Air Temperature
Inlet Air Temperature Sensor
Inlet Air Temperautre Sensor
Intake Air Charge Temp
Intake Air Charge Temp Sensor
J1850 Communication Bus
Knock Sensor #1
Knock Sensor #2
Leak Detection Pump Solenoid
Linear EGR Solenoid
Linear Intake Air Idle Control (IAC)
Linear Purge Solenoid
Manifold Absolute Pressure
Manifold Tuning Valve Solenoid (MTV)
Map Gauge Reading
Minimum Airflow Idle Speed
Minimum Pedal Position #1
Minimum Pedal Position #2
Minimum Throttle Position #1
Minimum Throttle Position #2
Modeled Ambient Temperature
Modeled Battery Temperature
Modeled Charge Temperature
O2 Sensor 1/1 State
O2 Sensor 1/2
O2 Sensor 1/2 State
O2 Sensor 1/3
O2 Sensor 1/3 State
O2 Sensor 2/1
O2 Sensor 2/1 State
O2 Sensor 2/2
O2 Sensor 2/2 State
O2 State Average
O2 Volts Average
Oil Pressure
Oil Pressure Sensor
Oil Pressure Switch
Output Shaft Speed
Overall Knock Retard
Part-Throttle Unlock Solenoid
Pedal Opening %
Pedal Position Sensor #1
Pedal Position Sensor #2
Positive Crankcase Ventilation (PCV)
Power Steering Switch
Present Gear
Purge Current F.BPWM O2 Heater Relay
Radiator Coolant Temp Sensor
Radiator Coolant Temperature
S/C A/D Switch InputSentry Key Immobilizer (SKIM)
Set Sync Mode
Spark Advance
Spark Advance Offset
Speed Control Relay
Speed Control Status
Speed Control Target
Theft Alarm Status
Theoretical Gov Pressure
Throttle Actuator Duty-Cycle
Throttle Opening %
Throttle Position #1 Limp-Home
Throttle Position #2 Limp-Home
Throttle Position Sensor #1 Signat Input
Throttle Position Sensor #2
Throttle-body temperature
Torque Reduction Status
Total Spark Advance
Transducer Offset
Transmission Fan Relay
Transmission Fluid Temp Sensor
Transmission Fluid Temperature
Vehicle Speed
Vehicle Theft Alarm (VTA)
Wastegate Duty-Cycle
Water-in-Fuel Sensor
And of course you can customize the display, data logging @ 40 parameters/second, data playback, export data to spreadsheets, blah blah blah....
Yes....fugly!
Seems to do a lot!:coffee:
But does it have a Starbucks Locator>?!!!:ylsmoke:
HButton
