Sensor cleaning
I like your work and I agree with your approach. Really close/wide rock-crawling shots like this one look great! Great magazine material and punch.
Which 28-300-mm lens are you using? That is a huge focal range, and I assume it is not particularly fast lens?
I was using a 20mm Canon f/2.8 prime on a 20D to get a focal crop factor of 32mm. Not really wide enough to be 'wide' or exciting but I was able to get most shots I needed with this combo, with plenty of compromises.
I recently purchased to a 5D and 24-70L f/2.8 which has provided some much needed flexibility. I use the 24mm a lot and don't plan on removing the lens often. Though this means I will also need to lug around the 20D with a much longer zoom on it for tele coverage (a heavy combo).
James
Dirty Harry said:
Yes, I think that is is mainly from changing lenses in the field. I recently purchased a 28-300mm lens that should limit the amount of swapping that I need to do, but I really like a wide angle (almost fisheye) for rockcrawling shots like this.
James
You are going to love that lens... 70% of everything I shoot is with that one lens.
I'm sure you are correct. I already love it!
Years ago I was going to buy the 28-70 f/2.8 but started using and liking other film cameras more than my Canons, so I never took the plunge. I got by with a cheap, consumer, slow 28-105mm when I needed a my Canon SLR.
I'm glad to have the extra 4mm of width. Not quite as wide as the 20mm prime but wide enough to look a little wide if I get close enough and do my part. This lens is very new to me and is just starting to get worn-in.
It is a f/3.5-5.6L L lens. Not the quickest (nor the lightest) but I really appreciate the range when shooting events. With the image stabilization I have found it to be fast enough for most situations.
I don't understand why you don't just bring your longer lens and leave the 20D body at home though???
I will sometimes. But as we all know, sensors likely get 'dirty' when changing lenses in the field, and avoiding the dirty sensor issue is nicer than having to clean one or send off for cosmetic DSLR surgery.
The 20D is a nice match for my f/2.8 70-200L lens, effectively making this lens a 112-320-mm with its 1.6X crop-factor. I think the jump from the 24-70 on the 5D to 112-mm with the 20D is a nice spread. And of course, having a back-up body is nice should one fail.
But you're right, much of the time I could just take the 70-200 'just in case' then I have it if I need it.
I think that makes a lot of sense to leave the longer lens on another body if you are going to be close to the vehicle. I just got done lugging my 8 pound 1DS and 7 pound lens up to 12,700 feet this weekend trying keep up with my girlfriend so it is hard to think about carrying MORE right now. I think when the time comes to get another body though I will likely do the same thing that you do. Do you carry them both in one bag or have seperate bags for each?
I had a conversation with my boss about sensor cleaning jsut thing morning. I get two nice spots on a bunch of wedding shots after I cleaned the sensor perfectly before the trip. Changing lenses does it and not always from outside dust. There is plenty inside that chamber from moving parts (mirror).
I use the VisibleDust stuff and it is too price for what it is, but it works. Funny thing though, I got something wet or oily on my brush last time and smeared it on the sensor :Wow1: I then bit the bullet and did what all the non-experts on the planet will tell you not to do.....I breathed on it to fog it up and used a Q-tip(r) to scrub it. Off came the goop. So yes, in most minds i made two mistakes. But the sensor is really stronger than you think and doesn't need to be super babied as people proport (people who have never manufactured a sensor in their life). I've done this before on other cameras and as long as you take care to make sure the q-tip is free of bad things and use light pressure, you can get smears off this way. the brushes are still more useful for dust, unless it's in the corner.
I agree size/weight is an issue and I would rather only carry one lens and camera. I have a medium size camera backpack that I never use that would handle both cameras and lenses (and more stuff) but other than this pack I don't have a bag that will fit both combinations. The 5D & 24-70 combo are only several weeks new to me so I don't have it all figured out :-) Obviously I would prefer to only carry this combo, but I be limited on tele range when I do.
The mirror box and the area surrounding the sensor is usually greasy. That is why you need a brush for the mirror box and another for the sensor. Be extremely careful not to contaminate the sensor brush.
ELShockley
