Set of 5 H2 Hummer Wheels with 315/70-17 BFG KO2's Mounted and Balanced!
vintageracer
To Infinity and Beyond!
Set of 5 H2 Hummer Wheels with 315/70-17 BFG KO2's Mounted and Balanced.
4 of the 315/70-17 BFG Tires are 75%+ tread mounted & balanced on NONE CHROME real H2 17 inch Hummer wheels. The fifth wheel/tire combo is the same with the exception that the tire was the spare tire. It is NEW never on the ground.
4 mounted tires/wheels have tire dates in the mid-year 2018 manufacturing time date. The never on ground spare tire has a mid-year 2013 manufacturing time date.
4 Original H2 Hummer Center Caps along with a full set of original GM Metric Lug-Nuts are included.
All 4 wheels are in nice condition.
These wheels are 8x 6.5 bolt pattern. Will bolt on any 8 Lug GM PU/Suburban trucks early 2011 and older. Must machine the center hole 3mm larger to mount on Ford or Dodge due to larger hub center. Bolt pattern is same 8 x 6.5 inch for Dodge and and 8 x 6.5 for Ford up to 1997 models.
Wheels/tires located in Nashville TN with local pickup the only option due to size and weight.
$700 for the set of 5 mounted tires/wheels!
Telephone Calls only PLEASE to 615 3477 459
ExpoMike
Too bad you are not in SoCal, I just happen to be looking for some. Good luck with the sale.
Mcoleman
