Shore power cord only?
adventureduo
Dave Druck [KI6LBB]
I just read in our AT manual (must have missed this part) that we should NOT use a standard extension cord for our shore power when charging the trailer.
I've had a regular extension cord plugged into the thing since we bought it with no problems to speak of. Is this just a general guideline or something i need to switch ASAP?
When i bought the trailer, i was just told a extension cord to plug in the port.
Just want to make sure im not going to screw up two Lifeline batts!
thanks guys
UK4X4
As a guess......it probably means not a $1.25 chinese ones
which melts with 1 amp...
But a good sized conducter extension cord which can handle the ampage if the batteries are flat.
For maintaining charge ....the chinese version would suffice..
jbs
I saw this in my manual too and I interpreted "standard" as 16 gauge. Especially for a longer run, this is not sufficient for much current load. I got a 25ft. 10 gauge cord, which I think is OK.
IH8RDS
My RV is the same way. If you need a durable extension cord you can pick one up at a local RV shop. The few times that I had to use a extension cord I could actually feel the heat off the cord. Definate fire hazzard.
adventureduo
Dave Druck [KI6LBB]
Ok, i think we're good then. We aren't getting any heat whatsoever from our cord. It's a average cord (not a cheapo) and its probably 15 feet long. Just wanted to make sure. Good thread for other trailer owners out their i suppose.
Mike S
Sponsor - AutoHomeUSA
I believe that the (expensive) marine shore power cords have a built-in fuse. They are designed for powering both 12V and 110V power suckers on a larger craft. A simple 'smart' charger is not pulling more than a few amps when running, and the draw drops as the battery charges up.
I use a good quality standard extension cord to power my on board charger that tends the twp 105 AH marine batts in my trailer.
M
Bergger
I saw this as well and asked Mario about it. He said a standard extension cord is fine for the Adventure Trailers. The manual is a bit generic on certain topics and the section you are refering to is more accurate if talking about large RV's.
