SlymerX Titan swapped 11' Nissan Xterra and 15' BMW R1200GS
    [IMG]
    Make: Nissan
    Year: 2011
    Model: Xterra
    Trim: Pro4X
    Color: Avalanche White
    Code Name: SlymerX
    Instagram - #SlymerX
    MODS
    Springy Thingies:
    Front
    - PRG Radflo's 2.5 t swap spec (600lbs coils)
    - PRG hiemed steering (tie rod ends)
    - SPC Titan UCA's
    - Titan LCA's (Movitech/Rock auto)
    - PRG extended steel braided brake lines (front)
    - PRG Poly steering rack bushings
    - PRG(SPC) cam bolts
    - Sway bar removed
    - SuperBumps Bump stops
    Rear
    - Alcan 4 inch leaf packs 600lbs over (Dual AAL removed)
    - PRG shackles on middle setting
    - 4 degree axle shims (WFO Concepts)
    - Bilstein 5165's in rear (24")
    - Titan rear brake lines (Rock Auto)
    - BORA 2 in spacers (rear)
    - PRG U-bolt flip kit
    - Timbren Bump Stops (Thank you LBX)
    - Shock Skids (picked up in garage sale, don't know what brand)
    Doughnuts:
    -Black Rhino Duggers 17x8.5 +10 offset. Mods to accommodate wheels- shaved calipers - cut bash rings to access valves for deflate/inflate
    -35x12.50r17 GoodYear UltraTerrains
    Exterior:
    - Offroad Gorilla hood shock mod
    - MacCarr 175lbs hitch shocks
    - Mud flap delete
    - Gobi Ladder
    - Melt mod
    - Trimmed fenders. (2.5 inch on bottom 1 inch on top. Bent/rolled, relocated stock mounts for fender liners.)
    - Stealth side body moldings
    - Bedlined rear quarters
    - MaxGear Aromor Roof Rack insert (Thank you Dave!)
    - DepHep roof rack net (works well enough with MaxGear rack)
    - Vhiggs Hood blackout
    S%$t to bang on rocks aka Armor:
    - Hefty Aluminum bumper
    - Shrock rear bumper with tire carrier (Max Gear rear bumper on order)
    - White Knuckles rock sliders
    - Hefty Fabworks aluminum skids (cut corner off gas skid to fit with WK sliders)
    - PRG diff cover
    Naughty Bits:
    - Interior L.E.D lights
    - Dep Hep rear window molle panels
    - Dep Hep front door molle panels
    - CoverKing tactical neoprene seat covers with molle panels.
    - The Original SunShade (best mod evah!):toothy10:
    Brainwaves:
    - Cobra 75WXST
    - 4 foot firestick
    - Midland 7122 handheld C.B. backup
    - Baofeng UV-5R83 handheld ham radio
    Under the skirt:
    - Titan 3 rib M205 -
    - Rugged Rocks 4:10 Gears
    - Titan CV's (Cardone HD)
    - Offroad Gorilla rear diff breather mod
    - Stock Nissan rear e locker. Open front.
    - Stock driveshaft
    What gets errr rollin':
    - BullyDog GT Pro tuner -
    - Volant (05' version)
    - Airflow Snorkel / Snorkel to Volant adapter sealed
    - Custom relocated horn for Volant easily 100 hp
    - XTP Intake Manifold Spacer (IMS)
    Gear:
    - Rhino Rack awning,
    - Nemo Roamer 4" backpacking air mattress with integrated sleeping bag for in car camping (This thing rocks :headbang:
    - WeatherTech Dog Ramp (For my 11 year Retriever to get in easily)
    - Raingler nets -
    - Traction Boards (for sale)
    - Viair 440p portable air compressor (This thing is a beast. Fills up 33's in no time. Side note: it takes a little time to cool down before I am comfortable packing it back in the truck
    - HF 20 ton bottle jack
    - HF 12 ton bottle jack
    - PowerBilt 3 ton jack/jackstand combo
    - Rhino USA 20' tow strap
    Sitting in garage waiting install:
    Future Mods:
    - Desert pin striping
    - Custom Moab ocean waves in quarter panels
    - Custom crater faced skids
    - Limit straps for front end
    Items for Sale: (PM) me
    - Traction Boards (2)
    - 33' DuraTrac's and P4X wheels set of (5) (locally)
    - 06' Titan spindles (sandblasted and powder coated), front calipers, rotors, and pads for titan brake swap
    - Bully Dog GT gas
    - PRG 1 inch coil spacers for after market coils
    I keep this updated if it's here it's still for sale
    Big trips planned:
    - What has now become the annual GoneMOAB/Overland Expo Extravaganza in May.
    - What has now become the annual Rubicon Trail outting every August
    - Ouray CO (Black Bear Pass) Summer 2020 - Can you believe I actually tired this on the 2 wheeler by myself? Yeah, I am actually that dumb. No wonder why the locals were laughing at me. But, I am really talented at picking that f$%ker up now.
  1. Mod 1- Titan Swap with M205. I used this video.
    M205 going in
    [IMG]
    A arms, Radflo's, brake line install
    [IMG]
    Alcan's, Bilstein 5165's, PRG shackles, titan brake lines, PRG diff cover, Timbren's, u-bolt flip kit, shock skids
    [IMG]
    All done
    [IMG]
    Mod 3 - Installed used WK sliders (sandblasted and PC), used shrock rear bumper, volant (12470) total PITA, and snorkel
    If I had to do this over again I would modify the box before I started installing. Install came out good.... but, there was a lot of fussing and cussing
    [IMG]
    Here are some photos of the amazing time I had trying to fit this square into a circle.
    I did perform a melt mod to the area that touches the brake lines. Unfortunately the pics don't show much.
    Reason Why opted for a snorkel is this pic. And the sandy desert air when trailing other rigs.
    [IMG]
    [IMG]
    Admittedly, drilling holes in the fender was scary at first. Honestly, nothing to worry about. The holes are way oversized and do not require perfection for a clean install.
    [IMG]
    [IMG]
    Sealing it up
    [IMG]
    Riveted the adapter on. A must do before installing the box. It is a very, very tight. I had to gently bend brake lines and an AC hose to get it in there.
    Note: The newer model Volant is easier to install. However, it has a gigantic hole in front of the box by the horn that most would want to seal. The 05 version (12470) is already sealed.
    [IMG]
    Mod 4 - Hefty front bumper and aluminum skids. Took 7 months from time of purchase to get these. At the time Hefty stopped offering options for this bumper. Can't get full cage they only make it one way now.
    Future installers - Be sure to check all items at FedEx before you sign. I was missing a bracket for the gas tank skid. Hefty promptly shipped new ones to me.
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    My best friend (da pup) likes the new bumper. Wrapped up the install during the super bowl.
    [IMG]
    Mod 5 - Max Gear roof rack install Thank you Dave (Maxterra)
    The green bag is a Gazelle T4 pop up tent. Its commonly bought for way less on other sites.
    https://www.gazelletents.com/Product/gazelle-camping-hub-tent-7177
    The box
    Raingler Net is the DepHep model. Works fine. Use ratchets and bungees for smaller loads
    [IMG]
    [IMG]
    [IMG]
  1. The inspiration for SlymerX Sometimes you just need 4 wheels.
    The ride: 2015 BMW R1200GS (Bought new. Now has ******** ton of miles). This is my daily
    Mods:
    Armor:
    -MotoArt valve cover guards,
    -SWMotech upper/lower crashbars
    -AltRider driveshaft skid
    -BarkBuster hand guards
    -BMW headlight protector
    -BMW engine skid plate
    Luggage:
    -Bumot Panniers/rack/rack mounted toolbox.
    -BMW duffel.
    -BMW GS tank bag
    -Givi 80L drybag.
    Misc:
    -Rox handlebar risers
    -BMW GPS
    -AltRider RotoPax rear seat delete mounts
    -BMW tented screen
    -PivotPegs w covers
    -AltRider rear brake extender
    -Stickers!
    -desert pin striping, custom rock bent mounts and crash bars with patina, custom wave shaped panniers.
    Completed Trips: Dalton Hwy AK, Copper Canyon Mexico,
    Black Bear Pass CO, Bear Tooth Pass MT, Entire PCH, 89 from Mex to Canada, Utah route 12, Going into the sun road (Glacier NP)MT, Black Hills S.D., Idaho BDR, The Pig Trail AR, The Dragon's Tail N.C.,
    Note: I have no idea how some of the photos in this thread turned themselves sideways one day....... Whiskey Tango Foxtrot
    //uploads.tapatalk-cdn.com/20190306/071a5cb3e16681aaca6017972a322d9f.jpg[/IMG]
    My apologies for the crooked photos. Haven't figured out how to fix it yet.
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
  1. Action pic time! GoneMoab 2019. Overland Expo West. Camping near Prescott, AZ and Sedona, AZ. Fun trip.
    [IMG]
    [IMG]
    [IMG]
    What happens when you mount your shock skids properly. You make custom extended automatic disconnecting shocks
    :D
    Basically my skids were installed with just the lower shock mounting bolt. I didn't drill a hole to mount a bolt to the diff's shock mount to keep it from flipping and snapping my shock in half. $240 lesson learned. Don't do what I did here.
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
    [IMG]
Cut fenders, added 1" body lift, 35's installed.
Measured for fender cuttage. 1 and 1/16 inch on top, tappered to 2 and 3/8" at bottom
measured for bending. (This was attempted, but failed)
used a flanging tool for bend
Cut out the factory mounts for wheel well liners to reinstall to new postion.
Cut around the 2 areas I planned on pop riveting the mounts back on too.
Pop riveted the mounts and bent them in. After test fit the wheel well liner didn't even come close to working
So back to the drawing board/ More cutting
Fenders cleared. On with the 35's
Off with 33" DuraTracs. On with 35" UltraTerrains
See a problem here? How the heck do you get air in these with the rash guards on? Oh, Black Rhino engineers screwed up. Will have to cut a half moon shaped hole with a pincel grinder in the bash rings so I can inflate/deflate my tires. Dammit man.
Also impact socket wouldn't fit to install lugs. Have to use regular sockets. In addition to shaving the calipers. So.....yeah.
2 of them used a lot of weight. 7oz. Other 2 were 2-3 oz. Not bad. Not the best. They were road forced.
Still need to reinstall the wheel well liners, sliders, and bedline the edges I cut the fender. Probably put door edge guard over the fender cut offs has well. Too bad the bending idea didn't work. But honestly, in person I like it better with just the straight cut. Fenders can easily be popped back out when they get dented.
clearwater
