smittybilt 2781 hose mod
Chazzi
Just wanted to share my hose mod in case anyone else was annoyed by having to run back to the air compressor and turn it off to measure your psi correctly with the smittybilt hose, I also changed out the tire chuck.
All you have to do is slide the valve up and it'll air up the tire or down to vent the air compressor and keep pressure on the gauge side so you can measure your psi accurately
When you install it make sure the flow arrow points to your compressor.
Parts used for anyone that wants something similar:
1x Coilhose Pneumatics BLSV04F04F Lockout Slide Valve, 1/4-Inch Female NPT in-Port, 1/4-Inch Female NPT Outlet
3x Anderson Metals 57001 Brass Hose Fitting, Adapter, 1/4" Barb x 1/4" NPT Male Pipe
1x AstroAI Open Flow Air Chuck
1x Precision Brand M4S Micro Seal, Miniature All Stainless Worm Gear Hose Clamp, 7/32" - 5/8" (Pack of 10) (only need 3)
Some teflon tape
Great no complaints, the bag it came with is falling apart. I do wish it had a pressure switch. We've used it to fill up tires and stand up paddle boards no problems.
empireoverlandza
