WolfRubicon
*******************SOLD!************************** Going to a good home!
1995 Land Rover Discovery 1 300 TDI 5-speed manual (7 passenger). Arles Blue w/ white roof, Gray interior. A/C is fully functional after swap and is cold! This Discovery 1 has a new re-stained dash w/ no airbags, no ABS. The gauges read in KM/H as this has all the correct glow plug lights and no unleaded logo. This Rover has ZERO rust issues. The doors and frame have been coated with Crest Honey Coat. Truck was repainted in 2012. No body damage or dents, and again, no rust. Headliner and interior are in great condition. This truck has no sunroof (bonus as it has no leaks)! It has a cloth interior and 94 style manual seats.
Have all documents on the conversion. Some of photos show truck with white wheels, they are now a semi-matte black to match the hood blackout decal.
Professionally converted in 2011 from V8 to 300 TDI by Cityside garage located in Holliston, MA. http://www.citysidegarage.com/ TDI had 78K when installed and has covered just over 22K since conversion.
Engine:
New Dayco Timing belt kit, new injectors, glow plugs, glow plug timer, new tensioner bearing, water pump, lift pump, PS pump, power steering box, all belts and hoses were replaced, silicone turbo hoses, new rear main seal and front cam seal, new battery June 2014, rebuilt injector pump, rebuilt alternator, full stainless steel exhaust, new engine and gearbox mounts. New Mantec snorkel!
Drivetrain:
New rear U-joint style driveshaft. Rebuilt double cardan front driveshaft with aluminum adapter. F swivel balls filled with one-shot grease. All new wheel bearings, races, and hub seals, freshly packed. All but rear shaft were done Spring 2014 along with brake overhaul.
Gearbox:
New clutch kit, resurfaced flywheel, throw out bearing and fork lever.
Brakes:
All new remanufactured brake calipers, brake rotors, and Ferodo brake pads on all four corners. +40mm stainless steel brake lines F&R. Fresh fluid. Brake overhaul done Spring 2014.
Suspension:
Brand new OME Heavy Duty springs F&R, new OME Nitrocharger shocks F&R, new F tubular shock towers, new Terrafirma lowered rear upper shock mounts, new F&R spring retainers, all installed Winter 2013.
General:
Safety Devices low profile roof rack w/ custom matte aluminum diamond plate (removable)! New rear door ladder. 5 new wolf military steel wheels, BFG A/T's 235/85R16. Rovertym rock sliders with extra side step and Rovertym winch bumper w/ steering guard. UK spec trailer mount (not currently installed). New gaskets on rear windows. Saudi Spec Front Grill! Hood blackout decal. Rear CB antenna mount and RG-58 coax ran to behind passenger dash, ready for radio/antenna install.
Interior:
All 5 doors have new actuators. Front doors have new window lift arms. Both front seats have new Exmoor Trim foam. All door handles have been replaced. New dash was installed and re-stained due to typical dash curl. Full set of matching factory seat covers. New ignition key tumbler, custom rear load space mat, and new rear aluminum door panel. New clutch and brake pedal pads. Entire floorpan has been covered with Monstaliner in matching grey color.
Lots of extra parts included: a set of matching front seats no rips or tears. All 4 door panels, all 4 windows and rails etc. rear wiper motor and arm, door actuators, A/C heater controls, plastic sill trim, door locks and hinges, extra switches and dash parts, etc. Have receipts for pretty much everything!
![Photo Apr 02, 5 32 04 PM.jpg Photo Apr 02, 5 32 04 PM.jpg](https://expeditionportal.com/forum/data/attachments/178/178756-3fc5be6bfd110825456d8a71009ccd44.jpg)
![Photo Feb 12, 4 17 01 PM.jpg Photo Feb 12, 4 17 01 PM.jpg](https://expeditionportal.com/forum/data/attachments/178/178758-eceea364bb19c8db06503908070e6921.jpg)
![Photo Feb 15, 3 04 29 PM.jpg Photo Feb 15, 3 04 29 PM.jpg](https://expeditionportal.com/forum/data/attachments/178/178759-138f58afb74938a39702ca83af20923e.jpg)
![Photo Jul 22, 11 31 18 AM.jpg Photo Jul 22, 11 31 18 AM.jpg](https://expeditionportal.com/forum/data/attachments/178/178760-d64a3951eb3cce0e89f2d142715947d2.jpg)
![Photo Jul 22, 11 31 31 AM.jpg Photo Jul 22, 11 31 31 AM.jpg](https://expeditionportal.com/forum/data/attachments/178/178762-71b771984bcb4f6c52382fa240c73532.jpg)
![Photo Jul 22, 11 32 44 AM.jpg Photo Jul 22, 11 32 44 AM.jpg](https://expeditionportal.com/forum/data/attachments/178/178765-2c121ea53b0c1b64d8c88036ea7e1eb4.jpg)
![Photo Jul 22, 11 33 03 AM.jpg Photo Jul 22, 11 33 03 AM.jpg](https://expeditionportal.com/forum/data/attachments/178/178766-604cd2b1ed73e0ea33e9bd719216f791.jpg)
![Photo Jul 22, 11 33 23 AM.jpg Photo Jul 22, 11 33 23 AM.jpg](https://expeditionportal.com/forum/data/attachments/178/178767-4ddcf21285a6ed0c6bc6a4288f5adade.jpg)
$17,000
wolfrubicon at g mail
Email/PM with any questions or if you'd like to see more photos. I have plenty! Thanks!
Engine:
Drivetrain:
Gearbox:
Brakes:
Suspension:
General:
Interior:
$17,000
