SOLD! 1999.5 7.3L DIESEL Powerstroke 4x4 Rigged for Truck camper a/o Heavy Towing $16,000 (Golden Gate, FL)
scottwstevenson
SOLD!!!
* Jasper Rebuilt Motor with ~15k miles on it. (446k miles on the truck)
1999 Ford F-350 Super Duty 7.3L Turbo Diesel DRW CrewCab Longbed 4x4 Lariat Automatic w/OD
Gold/Black $16,000
VIN: 1FTWW33F4XED05458
* Replaced Bed with Aluminum Flatbed in 2020 and added L-Track
-Has eyelets for Truck camper Tie-down (Tied Downs I’ve used come with truck)
-Mounted Aluminum L-Track for Truck boxes, etc.
-Side Tooley Lockable Tool Boxes with Slides. Mounted to L-Track
-Additional side boxes Mount to L-Track when not carrying camper
-Rear Tool box can be easily added if not carrying truck camper
-2x4 Slots for Rear Tailgate (The one I’ve made out of wood works great.)
* Gooseneck Hitch
* Ranch Hand BTF991BLR Legend Bullnose Front Bumper
-Winch Carrier with Storage
-Front Light Bar on Dash Switch
-Front Rock Lights on Dash Switch
* 13000-lb Load Capacity Electric Truck Winch Kit Synthetic Rope, Waterproof Off Road Winch for Jeep,Truck,SUV with Wirless Remote and Corded Control
* Ranch Hand Rear Bumper
-Rear Lights on Dash Switch
* SUPER HITCH® 30K frame mounted receiver rated up to 30,000 lbs pull and 3,000 lbs tongue weight with weight distribution (20,000 lbs pull and 2,500 lbs tongue otherwise) Greatly exceeds rating of the truck itself.
*Tow harness for trailer or gooseneck hitch, and 7 pin connector
*Rated to tow approximately #17,500
* Aftermarket Helwig Rear Anti-Sway Bar (Helps with towing big loads)!
* Torklift Stable Load (to further reduce sway - doesn’t seem to do much)
* Firestone Ride-Right airbags (This helps!
* Rear Overload Springs (5000k) (These do help on the big bumps when hauling a load)
* Front Steering Stabilizer Bar (Noticeable on highway.)
* Stereo with Bluetooth (Speakers still original, but at least there is BT connection)
* Rear Back up camera (glitchy - not working)
* Bed Camera for loading up Gooseneck (Super helpful for loading up the gooseneck.)
* Airdog fuel pump (filter just changed: 10/23 )
*4x4 system rebuilt in 2010 - electronic controls in the cab
*Custom piggy-back chip SELECT to increase towing performance, drive-ability & fuel economy (Seems to help somewhat, but I rarely use it.)
*GloPro pillar gauge for EGT, Boost and TRANSMISSION TEMP (nice for towing)
*Deep Aftermarket Aluminum Oil pan with cooling fins to help keep oil cool
* Rebuilt transmission in July 2011,~40k miles on it since then.
* Middle seat in front missing (cooler in place; not currently working)
* Front Seat Covers
* Rear bench replaced with platform for dogs: Has storage space underneath. (Rear bench can be found for a few hundred $ on facebook marketplace, from what I've seen. The one there was in bash shape . )
* Roof Rack Bars (and Thule carrier for free if you buy the truck!
*Oil/Filter just changed (10/23)
*Service Records for the past 5yr (since I bought it).
*Clean title in hand
scottwstevenson
Price drop to $8,000.
TL;DR: Only 15k miles on a Jasper rebuilt engine, new in the past 3-4 yr: Both Bumpers, Winch, Flatbed and Toolboxes, sway bar, steering stabilizer, overload springs, 30,000lb hitch and it's a 4x4 of course. :)
-S
