TuskMetalworks
**SOLD**
2002 Ford F-450 XLT 4x4 w/ 7.3L Power Stroke Turbo Diesel.
ONLY 19,850 Miles!
Super clean, fully loaded, low mileage, all original truck.
This Life Line ambulance was just retired from a small municipality in Colorado. Everything in the truck and box is fully operational and has all the bells and whistles. The truck and box, inside and out, reflect the low mileage. It looks as if it got virtually no use. It’s as close to new as you’ll likely see.
Truck and Box Specs:
-XLT package with all power options including heated mirrors and telescoping/adjustable accelerator and brake pedals.
-7.3 L PowerStroke diesel with only 19,850 miles.
-Ambulance package with dual 130amp alternators, engine block heater and Ford factory auxiliary idle control.
-Factory 4x4 with manual locking hubs and NP271-F transfer case, 4R100 4-speed HD automatic transmission.
-Dana Super 60 (6,000LB) Front, Dana 80/110? (11,000LB) Rear axle with 4.88 axle ratio, 165” wheelbase.
-Rear single leaf with Granning AirGlide airbag suspension and onboard factory air compressor system.
-40 gallon fuel tank.
-19.5” x 6” wheels, 225/70/19.5 tires, 50%, includes one new spare.
-Cab to box pass-through closable with sliding door.
-Factory heat and air conditioning in cab with auxiliary heat and air conditioning in box, with separate digital rear controls.
-Full build spec binder containing all electrical schematics, air ride suspension blueprints, Vanner Model 20 AC power inverter and charging system manual, warranty info... this is a complete guide to everything in this Ambulance build.
-All storage compartments fully illuminate with multiple access entry. Automatically lockable with the locking of the cab.
-Interior Box dimensions: 12' Long x 7' 6" Wide x 5' 9" Tall
The pictures speak for themselves. This truck is clean, clean, clean and runs great. It is the perfect start to a stellar build-out for a camper / expedition rig- a rugged Ford F450 4x4 chassis with a robust 7.3L diesel and its all close to new. Asking $37,500 or best reasonable offer. Shop around, you won’t find a truck this clean with under 20,000 miles and a 7.3 for less. If you do, definitely get it.
Located near St Cloud, MN 56303.
Call or text: 320-282-8674
ONLY 19,850 Miles!
