solspot
2005 4x4 Toyota Tundra Doube Cab Limited
Description: 4x4 Toyota Tundra Double Cab Limited 2UZ-FE 4.7L VVT-I V8 engine 5 speed automatic transmission. Gray Pearl paint, 4.7ltr V8, 5 spd Automatic Transmission.
Mileage: 157,xxx (daily driver)
Factory Options:
Tow Package with class 4 hitch/7-pin connector
Heavy Duty 130A Alternator
Transmission Oil Cooler
Limited Slip Differential
Heated Leather front seats
Power windows and doors
Power Heated Mirrors
Power Rear Sliding Window
Premium JBL Sound with Head unit replaced with Pioneer BT with Sirius XM, Hands free BT, Backup Camera
5-Spd Auto W/OD
Axle ratio 3.91
Sunroof
Airbags, frontal Driver And Front Passenger Airbags, side impact Seat Mounted, Driver And Passenger Airbags, side curtain Curtain 1st And 2nd Rows
Modifications
Suspension/Drive Train:
Total Chaos Upper Control Arms
Icon Front 2.5 VS IR COILOVER Extended travel
Icon Stage Rear 2.0 VS
Polyurethane Steering Rack Bushing
New OEM Lower Ball Joints
*all of the above with less than 5k miles
Firestone Rear Airbags inflated via 2 stems integrated into rear license plate
Wheels/Tires/Brakes:
5 Stealth Custom Series Ray-10
5 265/70/17 BFG KO2's
Second set of 5 stock Tundra Alloy wheels with mounted 265/70/17 BFG KO2's (still usable tread)
New slotted/drilled front rotors and brake pads (power stop)
New OEM rear brake drums and shoes
Diff Breather Modification
Electrical/Lighting:
All interior bulbs upgraded to LED including footwells
Switches for LED light bar and pods integrated into dashboard
New Headlight housings with Sylvania Silverstar Bulbs
LED bulbs replaced previous amber daylight running/parking lights (super bright and perfect for driving in a campground when you don't want to disturbed others)
Upgraded LED Fog Lights
X2 Power Battery
Blue Sea Systems 100 amp Fuse Block Terminal on Battery
Blue Sea Systems 150 amp dual bus in engine bay
0/1 gauge wire running from dual bus to rear of truck (tucked neatly within truck frame)
Blue Sea Systems Blade Fuse Box in Rear Bed
Blue Sea Systems panel (2 cigarette/power connection plus voltage reader)
2000 Watt Inverter (great for Desert Margaritas)
Truck Cap/Bed:
Rhino Liner
Snugtop Super sport with Sportsman Package (supports up to 500 pounds)
Limo Tint on all windows
Sealed entry to full sliding rear window of truck (double sealed to keep any dust out). The DC tundra's have a full sliding rear window.
Yakima Rack System
Removable Baja rack with 36 inch LED light bar and two rear LED pods controlled from inside cab. Quick connects on truck make removal of both rack and lights simple (quick connect wires and mount system to Yakima round bars)
ARB Awning w/sidewall connected to rear of baja rack. Pulls out to cover tailgate and beyond.
Ceiling mounted LED light strips (very bright)
Custom Built bed system from cabinet grade birch plywood
4 small removable storage areas front and rear
large opening center near rear window with hidden hinges
2 removable sheets at the rear tailgate
perfect system for storing surfboards on one side (2 boards can be stored underneath with fins removed and under 6')
on the other side I use a plastic bin to store wetsuits (but can be modified to store a slide out refrigerator/stove)
*system is removable if desired
Other:
100 Watt Renogy Portable/Foldable Solar Panel w/20A controller
Weathertech floor mats
This truck is in fantastic condition. I would not hesitate to drive this cross country, to the tip of baja or south america!
Price: 21k
