[SOLD] 2006 EarthRoamer XV-LT - Rare interior - Sleeps 5
mk216v
Der Chef der Fahrzeuge
This EarthRoamer has been very well-maintained, as well as upgraded to a high standard, which makes this particular XV-LT stand out amongst other off-road campers.
Features a rarely seen ER interior arrangement; can sleep 5.
In fantastic shape for its generation, and eager for more adventures (including being the sweetest mobile ski lodge at the slopes this winter).
Hard to find a rig like this one!
OVERVIEW:
  • Truck: 2006 Ford F550 SuperDuty Lariat CrewCab 4WD
  • Engine/Mileage: ~139,xxx miles (has ~14,xxx miles on a fully rebuilt/bulletproofed 6.0L long block--further details below. NO DEF FLUID to deal with!!)
  • Color: Metallic Silver
  • Build #: 00-43
  • Price: $159k
STANDARD EARTHROAMER FEATURES:
  • See 3 pictures below for full details
ADDITIONAL EARTHROAMER OPTIONS:
Camper interior:
  • 1 of 3 XV-LT's ever optioned in this rare full-length sofa configuration on passenger side (sofa slides out into a 42x73" bed)
  • Dual tables (or an armrest) on Lagun-type mounts at ends of sofa
  • L-track cargo tie-downs at sofa
  • Above-sofa sling/gurney bed provision (currently 4 mounts only)
  • Driver side kitchen galley
  • Under-galley slide-out drawer
  • 8.1 cu.ft. Vitrifrigo fridge/freezer
  • Arctic package (exterior tanks further insulated, 85gal fresh water tank has heating element/Freeze Protect circuit)
  • Electric gray tank valve
Electrical:
  • 1080Ah battery upgrade (Lifeline AGM)
  • 525watts solar
  • Fast charge function
  • 4channel 600watt Pioneer amplifier and 4 upgraded speakers
Exterior:
  • ARB front air locker
  • Hella 4000 off-road lights (recently upgraded--see below)
  • King shocks and Kelderman/AccuAir air suspension w/ in-dash controller
  • 335/80/20 Continental MPT81 (41") tires with 20" Hutchinson 3pc beadlock wheels
  • 90gallon (50gal front, 40gal rear) fuel capacity w/ OEM Ford front/rear switch
  • 16,500lb Warn 16.5Ti electric winch w/ synthetic line
MAINTENANCE AND UPGRADES:
Camper:
  • EarthRoamer 500pt inspection/service; including new Xantrex 3000watt inverter and inverter controller, bunk window stays, hatch/fan seals, window seals, door seals, upper & lower storage locker seals, etc etc
  • Kwikee entry steps
  • MaxxAir Plus 10spd roof vent fan in wet bath; exhaust and intake, w/ rain sensor, remote control
  • MaxxAir Deluxe 10spd roof vent fan above galley; exhaust and intake, w/ thermostat, rain cover, remote control
  • Secop electronic control unit for Vitrifrigo fridge/freezer
Truck Interior/Exterior:
  • Bluetooth stereo head unit, backup camera
  • Edge Insight CTS3 in-cab gauge monitor
  • Rayno S9 VLT ceramic window tint
  • Ford/MKM '05-07 SuperDuty honeycomb grille
  • Weathertech side window deflectors/rain guards
  • Osram/Sylvania LED marker light bulbs
  • OEM headlight assemblies, Lightwerkz bi-LED projector conversion
  • Triple-R Sentinel 9" Elite LED off-road lights w/ security hardware
  • EarthRoamer updated vinyl logos
  • *ADD'L COST OPTION; Custom Scheel-Mann VarioR 14way adjustable orthopedic seats w/ seat heaters in AS211 gray leatherette and Ford "RS" logo/blue stitching, w/ Planted Technology seat brackets. While these normally cost over $6500, add $3000 to the vehicle price to keep them installed. Otherwise, the OEM Ford gray leather front seats (heated) which are in fantastic shape, although not even close in support/comfort for long-distance driving as the Scheel-Mann's are, will be re-installed.
Engine/Mechanicals:
  • Fully rebuilt/balanced/Bulletproofed J&K Engines stage3 6.0L long block; ARP head studs, ARP main studs, o-ring cyl heads, billet chromoly pushrod set, coated HD piston set, coated bearings, OEM Ford high and low pressure oil pumps w/ front engine cover, oil cooler, updated standpipes, gaskets, premium injector set, glow plugs/harnesses, exhaust backpressure sensor, thermostat, upper/lower radiator hoses, oil pressure switch, belt tensioners, belts, idler pulleys, coolant reservoir, coolant re-route kit, Bulletproof water pump, BorgWarner S362 T4 turbo kit w/ billet pedestal&wheel/360 thrust bearing/heat wrapped SS304 up-pipes, S3R ported intake manifold, Mishimoto radiator, Suncoast HD billet flex plate, SCT tuner, etc
  • MBRP stainless 4" exhaust w/ 3.5" downpipe
  • Riffraff Diesel turbo outlet CAC hose
  • Both OEM Ford starting batteries
  • OEM Ford/Lincoln left front air suspension height sensor
  • OEM Ford rear swaybar end links
  • OEM Ford oil cooler re-seal
  • OEM Ford windshield washer pump
  • OEM Ford primary and secondary fuel filters
  • Rear wheel bearings/races/axle seals, transmission filter/fluid + Mag-Hytec high capacity transmission pan (holds add'l 8.3qts fluid!), front and rear diff fluids, transfer case fluid, brake flush, oil change service
  • Warn locking front hub set (black)
  • AccuAir offroad emergency repair kit--new in packaging
  • SafeJack 12ton RV jack kit--new in packaging
I have the original EarthRoamer XV-LT owner’s manual binder with records.
In transparency, this vehicle has been used for what it was built for vs just sitting pretty in a warehouse, and as such, there are some nicks/scratches/scrapes/blemishes.
Note; The glass cooktop on the Wallas diesel stove has recently cracked. Since there are pros/cons to retaining a diesel stove vs switching to an induction cooktop for example, the vehicle price is reflective of the buyer handling this post sale so as to best suit them and their preference (I can advise on a resource for a new glass cooktop if it's helpful).
Selling this dream rig as unfortunately my plans for remote work/travel with it have fallen through. :(
Clean Oregon title in hand. Serious inquiries only please. Partial trades considered.
Kept in a climate-controlled garage near Bend, OR. I can pick you up at the Redmond, OR airport for your off-grid adventure back home.
The merit of a usable and affordable (and not too over-the-top) ER XV-LT that's been upgraded to this level is probably obvious. But you likely don't know of Jeremy's forthright and professional nature and his attention to detail, though I suspect it's pretty evident in the information and photos posted above. I've dealt with Jeremy both professionally through his business and personally on a handful of trail runs and his desire to have things 'just right' is pretty awesome. If this is the sort of thing you need, I think you'd enjoy working with him on the purchase.
Can anyone understand how earthromer explains the bed situation? I am a family of 5 and trying to figure it out!
- "Bench seats convert to long twin bed in bench seat layout"
and
- "Sofa converts to twin bed in optional sofa layout"
Unless this thing is a transformer, I see a king bed cab-over and a long twin bed.
Sleeps 4?
and
Sleeps 4?
I suspect this, from the original post:
  • Above-sofa sling/hammock bed provision (currently mounts only)
Although I do not know what “currently mounts only means.”
I totally missed this. Thanks!
I assume it means the mounts are there, but he doesn't have the hammock itself?
LukeSkywalker515
