SOLD - 2010 AT FlipPac Camper for Small/Mid Size Truck 6' Bed
bbpinzi
Description: (Camper only, truck not included)
FlipPac Camper for small or mid size truck installed new by Adventure Trailers in 2010. Original top fabric, torsion bar, and top hinges. Mostly garaged since new. Did sit outside one winter covered with a water proof tarp. Camper opens up providing a full size (double) bed. Headliner which keeps the top fabric and bows stowed when closed may be used as a hammock for a child or up to 150lbs. Weight is approximately 325 lbs.
Camper includes all external items I’ve attached to it while owned:
  • Fiammia F35 Awning (Legs may be attached to side brackets on vehicle or staked to ground)
  • Right, Left, and Rear LED Flood Lights
  • Sony Backup Camera (Requires analog monitor in cab)
  • Diamond K-9000 motorized antenna mount with NMO connector and cable (may be used for amateur 2m/70cm, GMRS, or FRS radio)
Also included:
  • Original crank to open and close the camper
  • OEM Rain Fly
  • SLO Sail and Canvas Rail Fly
  • New set of Brophy Cable 1000 lb Camper Jacks
Price: $6,000
Known Problems:
Camper is painted medium gold color. Was supposed to match my Tacoma but I believe it was painted a similar but not exact Ford truck color. There are small paint chips and extensive pin striping from off road use. Interior electric lights do not work. Wire was nicked when installing the K-9000 antenna mount. One fabric “ear” covering the hinge area when open has come off but is included.
Right Side View Closed.jpgAwning Legs on Ground.jpgAwning Legs on Truck.jpgFront Open.jpgHammock.jpgK9000 and Left Flood Light.jpgBed.jpg
