I am the second owner of this 2013 Jeep Rubicon Unlimited. I purchased the Jeep in June 2015 to use on a back-country road trip in the Western United States. After 10,500 miles racked up during our 2 and a half months on the road, mileage stands at 61,943.
You will be hard-pressed to find a better-equipped and more capable adventure vehicle that can literally go anywhere. This Jeep was converted in 2013 using $40,000 in parts and labor with professional installation being done at AT Overland in Prescott, AZ. Additionally, This Jeep Rubicon comes factory equipped with Dana 44s with front and rear locking differentials, front sway bar disconnect, 4:1 transfer case gear ratio, factory skid plates and rocker protection!
Nearly all the comforts of a full size RV, built on a small “go anywhere” platform.
This includes 18.2 gal of fresh water capacity, exterior shower system (w/ full enclosure) with hot water heater and high-pressure pump, dual battery charging system with starting battery isolator and low-voltage disconnect, National Luna Fridge and Freezer, Partner Steel stove, and loads of lockable storage. Also, the ability to haul and comfortable sleep two adults (a third is possible), along with the security of an on-board air compressor, 10 gal of extra fuel storage and top of the line recovery equipment.
With this Jeep, you get one of the highest quality rooftop tents available with the James Baroud Discovery Extreme and still have the option to remove the “Freedom Panels” on a sunny day, so you can go “topless” as Jeeps were intended. The Discovery Extreme tent provides the capability to carry an additional full size tire giving this Jeep a total spare tire capacity of 2!
AT Overland did a fantastic installation/conversion. The wiring is impeccable, and everything has the fit and finish of a factory production vehicle. They stand behind their work and products 100%.
In some ways, this is a better Jeep than when I purchased. The dual battery controller had issues immediately, however, AT Overland stood by the product and replaced the unit when we swung by their shop on our return. I also had the front rotors and pads replaced as well as a full brake system flush back in September at 56600 miles. Additionally, the brackets that secure the tent closed were stressed. James Baroud sent out new brackets that had been redesigned to provide better clearance and more leverage when closing. The Jeep comes with full Sirius satellite radio activated through July 2016.
Fill up the fridge/freezer, top off the LP tank and take off on your next adventure! One caveat is that, although the tires still have around 20% tread, they were really used on the trail so should be replaced. Currently, lots of road noise. Since tires can be a very personal preference, I have elected to not put new tires on the vehicle. Additional accessories (and only a few months old) like Garmin GPS, Delorme InReach Explorer Satellite communication device, Camping Utensils, Camping seats quality bedding, including a great comforter from Cuddledown that has been field tested down to 29F can be negotiated to be included with the sale.
Factory Options:
5 Speed Automatic Transmission
Max Tow Package
4.10 Gear Ratio
Heated Seats
3-Piece Hard-top
UConnect System
Sirius Satellite Radio
CD Player
120 volt outlet on console
Factory Sub woofer
Aftermarket Additions
EXTERIOR
Bumpers / Recovery
AEV JK Premium Front Bumper includes: Tow Loops, Off Road Light Brackets, Stainless Steel Mesh, Crush Cans, Crush Can Covers, Factory Fog Lights
AEV Front Bumper Winch Mount
Warn 9.5 cti electric recovery winch with synthetic line and hawse fairlead and Factor 55 Flat Link shackle mount
AEV front license plate mount and bracket
AEV Front Skid plate: Protects sway bar, impact beam, and steering
AEV Rear Bumper with built in water tank (pump kit included) and tire carrier
AEV Spare Tire Carrier Fuel Caddy 10.2 Gallons-Black.
AEV Hi-Lift / Pull Pal mount for rear bumper with High Lift jack, Pull Pal (land anchor for self-recovery) and shovel mounted
Custom sand ladder mount and sand ladders
Suspension
AEV 2.5” Dual Sport XT Suspension - Frequency-Tuned Progressive Rate Springs, Bump stop Spacers, Rear Stabilizer End Links, Rear Track bar Tower, Rear Track Bar, Front Brake line Droop Brackets
Adjustable Air Lift air springs in rear
Geometry Correction Front Control Arm Brackets
Offroad Evolution manual sway bar disconnect (you will also get factory electronic sway bar disconnect in full 100% working order)
Exterior Electrical / Lighting
Dual Battery Tray with Remy Intimidator Dual Purpose Starting/Cycling Batteries
National Luna Split Charging Kit with Intelligent Solenoid (battery isolator), Voltage Monitor with added 30A 12V Adjustable Low Voltage Disconnect (LVD) (protects battery from over-discharge)
Baja Designs Squadron Combo LED Lights (2)
Baja Designs Pre-Runner 6” HID Lights with rock guards (2)
6 LED Rectangular HD Flood Light for reverse light
Exterior Accessories
EXTREMEAIRE 12 volt Compressor – hard-mounted under Jeep with custom skid plate. Quick disconnect ports at front and rear bumper. Pressure regulator/safety check valve/compressor intake snorkel – all located under hood.
AT Overland Custom Aluminum 10 lb Propane Cylinder Bracket & clamp and Rear JK External Accessory Bracket
Hannibal Awning 2.4M with all four Enclosure Walls – mounted above passenger side doors
Custom awning mount above tailgate door with custom awning (Width 39” Length 8’.6”)
MBRP Roof rack with custom ladder and light bar
James Baroud Discovery Extreme Rooftop Tent with spare tire storage (more than 3 years left of full replacement manufacturer warranty)
Offroad Elements M8 Stealth Limb Riser Kit
AEV Snorkel with Pre-filter Assembly
Locking gas cap
Hood Lock
Vector Offroad Exo Rack spare tire / accessory rack
MOPAR Steel Winter wheels
Hitch Safe locking security box for spare key/other valuables
INTERIOR
Storage
AT Overland - Stage 1 Composite drawer and Stage 2 Composite twin-top loading compartment with custom factory sub-woofer install
AT Overland Jeep JK Interior Cargo Rack with custom mount for Eezi-Awn K9 Stainless Steel Camp Table
Interior Electrical
A-Pillar Switch Pod and Rocker Switches (controls Air Compressor, Accessory Lights, and Hot Water Heater)
National Luna Weekender 50L Fridge/Freezer Split (Stainless Steel)
On Combo slide w/ Partner Steel Stove w/ wind screen
National Luna 15-LED Light - custom mounted on tailgate window to illuminate outdoor kitchen
Kenwood Reverse Camera with Advent LCDM40A Rear view Mirror (monitor screen in mirror)
AEV ProCal Module
Shower / Water System
Nautic Junior Stainless Steel Hot Water Tank. 6liters (1.32 Gallons). 12 volt heat element model, 200 watts with 20A circuit breaker [Housed under Stage 2 Composite Compartment]
13.2gal. Water Tank [Housed under Stage 2 Composite Compartment]
Universal Pump + Strainer - 12volt Hp, 30 psi [Housed under Stage 2 Composite Compartment]
External Hot/Cold Shower Point, mixer valve, shower head and hose assembly
Stainless Steel Fill Point for Water Tank
Interior Accessories
Trailgator fold down tailgate table and cutting board
Two fire extinguishers and mounts (one at kitchen area – one at driver’s seat)
Trek Armor seat covers (front)
AEV All Weather Floor liner (front)
Extreme Terrain Interior Cargo Nets
Yeti bottle opener (mounted on interior of tailgate)
Locking Security Boxes under driver and passenger seat
Offered at $41,500
![20151117_081556.jpg 20151117_081556.jpg](https://expeditionportal.com/forum/data/attachments/241/241920-1630cf508b186a06c389274be3d1ab0d.jpg)
![20151117_081958.jpg 20151117_081958.jpg](https://expeditionportal.com/forum/data/attachments/241/241921-3d612fd8062b093fc677227b5a85dce0.jpg)
![20151117_081737.jpg 20151117_081737.jpg](https://expeditionportal.com/forum/data/attachments/241/241922-a18175a62fcf560bba5421b06cc4bcc4.jpg)
![20151117_081803.jpg 20151117_081803.jpg](https://expeditionportal.com/forum/data/attachments/241/241923-923cf314d85b94cf9a23bb699d5c3429.jpg)
![20151117_082115.jpg 20151117_082115.jpg](https://expeditionportal.com/forum/data/attachments/241/241924-058e7371524dc438c24d52ec3b13989c.jpg)
![20151117_081646.jpg 20151117_081646.jpg](https://expeditionportal.com/forum/data/attachments/241/241925-e3f9ebbb4a3af975803af8d224148325.jpg)
![20151117_082206.jpg 20151117_082206.jpg](https://expeditionportal.com/forum/data/attachments/241/241926-d0cbcc0f96d2fa533f5f074a7aba37e3.jpg)
![20151117_082222.jpg 20151117_082222.jpg](https://expeditionportal.com/forum/data/attachments/241/241927-60ab4a36bacf3b71fb15455220003419.jpg)
![20151117_081834.jpg 20151117_081834.jpg](https://expeditionportal.com/forum/data/attachments/241/241928-1d7d41442f2ede0a22710e5baa1cef69.jpg)
![Jeep1.jpg Jeep1.jpg](https://expeditionportal.com/forum/data/attachments/233/233258-ac06076e11ee48fb8ac708404004aaa1.jpg)
Factory Options:
Max Tow Package
4.10 Gear Ratio
Heated Seats
3-Piece Hard-top
UConnect System
CD Player
Factory Sub woofer
EXTERIOR
Bumpers / Recovery
Suspension
Locking gas cap
Hood Lock
INTERIOR
Storage
Interior Electrical
AEV ProCal Module
Offered at $41,500
