*SOLD* 2013 Kodiak Adventure Products Mirror Lake Teardrop Trailer
Bulldoug
Putting up my 2013 Kodiak Adventure Products Mirror Lake Teardrop Trailer for sale, 2nd owner and had now for about 5 years. Great teardrop trailer that stands out from the rest in terms of not only looks but more so quality and toughness of built. Has been to alot of cool camping spots out of the way. It's time for a new project and someone else to enjoy it.
Construction and Specs:
Ultralight composite construction
Vacuum molded foam core composite
Powder coated Heavy duty welded frame
Brand new heavy duty axle
Leaf sprung with brand new tuned mono tube shock suspension and new Electric trailer brakes
Tube fenders & Frame integrated rock rails, with full roll cage (unbolts from lower section). Built in table holder on top.
33 Inch All Terrains on a set of polished 3piece wheels - Toyota Bolt pattern.
Max coupler hitch
Approximately 1300 pound
Electrical:
AGM battery
National Luna battery monitor
Marinco charger 110 VAC shore power connection
LED side marker, tail and brake lights
USB and cigarette outlets (outside and inside)
SAE connection at back for Solar Charging
Water System:
11 gallon water tank (mounted directly above axle)
Shurflo (4008 series) water pump with In-line water filter
Frame mounted ¼ turn water spigot (Connect hose or use as spigot)
Interior:
High end custom mattress (one season old)
Miniature LED light strip bar for interior lighting
Maxx Air fan - in and out, speed selectable.
Molle panel on middle wall with side hooks for clothing/first aid/etc
Tinted windows with bug screens
Hidden internal storage space under mattress
Exterior:
Custom fabricated aluminum side storage box (locking)
Custom stainless steel table (fits in storage box)
Galley / storage area with small Fridge/Freezer
EeziAwn 1000 awning with aluminum case
Plastic Tongue box
Diamond plate rock guard
Tongue jack (needs to be replaced, new one will be provided)
Located outside Calgary, Alberta, Canada
$17,000 Canadian obo
PM for more details and contact info
tbnd88
