SOLD - 2016 Turtleback Expedition Trailer with CVT Mt Denali RTT - immaculate condition, located in Boise, ID
pahskahl
Gently used 2016 Turtleback Expedition trailer in a custom tan color with matching CVT Mt. Denali CV Summit Hybrid RTT and many accessories. Turtlebacks are extremely dependable and durably-built trailers that will track both at speed and through rougher terrain without skipping a beat. With a full kitchen and 42 + 6 (in the water heater) gallons of water on board, a dual AGM battery electrical system with pure sine wave inverter and solar charge controller and flexible 90W solar panel, and dual propane powered water heater and Partner Steel cooktop, you can take your off-grid adventures and dry camping to the next level. The largest Mt Denali Summit CVT tent mounted on top of a robust rack system measures 87” wide, and can sleep 4 (or more) very comfortably. The included full annex drops down for an enclosed and screened area adjacent to the trailer.
We’ve enjoyed owning it for the past few years, and are now ready to move to a different type of adventure setup. It’s been meticulously cared for - all systems and functions operate as they did when new, the wood finishes show virtually no signs of wear, and the trailer is rust and damage-free, save for some small nicks on the nose box from gravel. We have only used the trailer on fire roads and in established and/or dispersed campgrounds (no hardcore off-roading). When not in use, it has been stored in a climate-controlled garage, and the water systems have been cleaned a minimum of 2x annually. It is now ready to go to a new home. This trailer has almost every option offered by Turtleback at the time of build.
Price - $XX,XXX OBO
Located in Boise, ID
Title is free and clear and in-hand.
Trailer history: I’m the third owner, it was originally used by CB Adventure Supply for 3 months as a show trailer. Then purchased by the second owner in 2017 and based out of the Salt Lake City area. I purchased the trailer in mid-2019, added a brand new CVT tent, and the trailer has seen very little use since then out of its new home in California. It moved with us to Boise, ID, where it has been stored in a climate-controlled garage.
Standard Equipment:
Full Steel Trailer 2x3 Perimeter Box Frame, 3500# stub UCF Flexride Rubber Torsion axles 2750# Springs, 10" Electric Brakes, 16" Steel Wheels, 265/75-R16 BFG KM3 BFG Tires, Forward and Aft Receiver Hitch on Frame, Bedliner Coated Chassis, 0.060" White Aluminum Skin, 2 Side and 1 Rear Compartment Doors w/ Matching Keys, LED Lighting, 11# Propane Tank with Stainless Steel Bracket, 2 Deka Group 24 AGM Marine Batteries in Boxes with Blue Sea Fused Terminal Block, Blue Sea Systems® Marine Grade Electrical Components, 4 Rail Cargo Bar Roof Rack, 2000# Swing Away Tongue Jack with Foot, Safety Chains, 7 Way Round Trailer Plug Wired to: Running, Brake, Turn, Charge Line & Trailer Brakes, Interior Lighting in Cargo Area and Kitchen, Exterior perimeter lighting all around, 42 Gallon Food Grade Fresh Water Tank (BPA Free Construction), Flowjet 12v Demand Water Pump, Atwood 6 Gallon DSI Water Heater, Exterior Shower with stainless 10’ shower hose, Baltic Birch Pantry Drawers in Kitchen Area, Baltic Birch Slide Out Kitchen with 2 Drawers, 2-Burner Partner Steel Stove, Dometic Deep Basin Stainless Steel Sink with Hot & Cold Faucet and tempered glass lid/prep surface.
Tailgate - Includes 18”x36” brushed stainless steel fold down table, spare tire mount, spare idler hub with greased bearings, Turtleback Trailers Rotopax dual 4-gallon locking mount.
48"x32" Nose Box, 45" Side Box, 25" Side Box Our Storage Box Set are constructed in house using CNC Laser cut aluminum. Then they are CNC bent to insure the perfect fit. Our welder TIG welds them together then they are powder coated in and out. We finish the assembly with 1/16 stainless rope to hold the doors at a 90 degree for additional table space. We line the door with Baltic Birch inserts and seal the doors with 3/8" rubber bulb seal that is connected with a steal re-enforced pinch welt. We use polished stainless like keyed latches. Includes Blue Sea 1 Battery Disconnect, Blue Sea 6 Circuit Fuse Block, 6 Amp Marine Battery 2 Bank Charger (Shore Power), 10 Amp Solar controller with Voltage Meter.
Options/Upgrades:
-Custom Tan Color
-Picnic Table Mount with 2 Lifetime 6’ tables
-Locking storage tube for poles, rods, etc
-Spare Full-Size Matching Tire and Wheel
-Receiver Lock Plug
-UCF Spare Spindle
-Battery and Electrical System Upgrade
-90 Watt Rollable Solar Panel – works great to keep batteries topped up for indefinite dry camping
-Additional Charge Ports
-2000W Pure Sine Inverter Package
-Additional Grill Propane Tank and tank mount
-Partner Steel Stove with Partner Steel aluminum griddle – best cooking surface for the stove!
-Dometic deep basin stainless sink with tempered glass cover
-Stainless steel 10’ shower hose
-2 4-Gallon RotoPax Fuel Cans with RotoPax Deluxe and Extended Mounts
-Foxwing 270-Degree Awning in excellent condition
-2-Foxwing Tapered Awning Extensions
-Telescoping Awning Slide on the Turtleback allowing you to raise/lower the awning height
-CVT Mt. Denali EV Summit Hybrid roof top tent in tan color with fiberglass base, dual telescoping ladders, full annex room, and floor. This is the largest tent at 87” wide, easily sleeps 4 or more. Only ~14 nights on this tent!
-Max Coupler 6,000# articulating trailer hitch
-Also Includes standard 2” ball hitch
-Custom fabricated fridge slide mounts will be included in the sale (no slide or fridge included)
pahskahl
Thanks for asking - I believe it's right around 1,800lbs dry, and then of course depends on what you load it up with. The RTT is around 260lbs IIRC. A full tank of water (48 gallons) is another 384 lbs.
donaldsonmp3
