SOLD: 2017 5x9 Off-Road Deluxe Hiker Trailer
Hey there. I posted this a while back and then decided to hang on to it for a bit but it's definitely time now. It's been an awesome trailer and I'll be sad to see it go. Only reason I'm selling is b/c I don't need the extra space anymore and would rather have the money to put into building up the truck.
Most of the photos were taken from when new until earlier this summer. I took it on a couple of trips this fall too. Only issues that I don't have recent photos of is that the paint on the front of the frame and fenders is chipping from gravel road driving. It could be touched up with a rattle can. I had planned on getting it Line-X'd next spring but won't have the time to deal with that now. Either way, I'd recommend and plan on doing that to any trailer you end up buying if it doesn't have it already done. Also, I had just replaced both awnings with the newer models earlier this summer and both have only been used twice since then.
Build Sheet + Add-Ons (both factory and self installed):
2017 5x9 Off-Road Deluxe Hiker Trailer: $9,595.00
Black painted 2x3 Frame
3500 lb Trailer axle
32” Tires w/ painted Steel 17" Wheels
Two Front Trailer Jacks
Two Rear Drop-down Jacks
Two Rear Tow Shackles
Front Black Storage Box
7 Pin Wire Harness
Front Rack
2" Rear Receiver Hitch
Sleeping Area has 2-battery powered Light and 1 120 Volt Power Step
Manual Roof Vent
LED Side Marker Lights
DOT Approved LED Rear Brake and turn signals
Lights License Plate Holder and Light
Flooring is made of ¾ weather resistant plywood overlaid with vinyl flooring
Bottom is undercoated
Trailer sides are 3/4” Plywood
Exposed interior Components are Birch and Varnished Natural
Exterior of Trailer is skinned with White Aluminum
1 Exterior White Door with w/ Lock
2 Operable Black Windows
Large Rear Side Opening Galley Door
Deluxe Cabinets
Customer Addons: $10,049.00
Black Door w/Windows and Screen Doors($150.00)
Second Street Door ($300.00)
Wall Color - Dark Grey ($150.00)
Front Diamond Plate 24" Black ($65.00)
Black Trim ($50.00)
Roof Rack ($175.00)
Rear Mount Swingout Spare Tire Carrier w/added two position lockout pop pin($450.00)
2" Receiver on Spare Tire Carrier [Bike rack + 2 bikes can be swung out with tire carrier to access rear door. Otherwise, with rack mounted in bumper receiver the rack has to removed to access rear door] ($50.00)
Electric Brakes w/ Breakaway kit ($250.00)
11lb. Propane Tank Mount ($150.00)
11lb. Worthington Propane Tank w/propane ($80.00)
Fantastic Fan Vent w/ Light Ring ($250.00)
Under Storage Cargo Pan ($400.00)
Lock-N-Roll Multi-Axis Coupler ($390.00)
Trimax Hitch Lock Set Keyed Alike ($75.00)
3 Black Alloy Wheels - KMC XD 17x8, 4.5” Backspacing, 0mm Offset ($450.00)
3 General Grabber AT2 Tires - 265/70R17 ($420.00)
Electrical Package 2 w/80w Zamp Solar Panel, 600w Zamp Inverter, Noco Battery Charger, Type 27 Deep Cycle Battery ($1484.00)
110 V Wiring Front Cab to Rear ($50.00)
110 V Wiring Front Box to Rear ($50.00)
12 Volt Prep ($200.00)
2 Side Exterior Lights - Labcraft Si7 Scenelite [Imported from UK and bright AF] ($200)
1 Rear Exterior Light ($100.00)
2 Under Cabinet 12v Lights ($50.00)
2 Recessed 12v Reading Lights ($30.00)
12V Outlet in Front Box and Rear Galley ($25.00)
120V Surge Protector and USB Outlets in Front Cabinet ($25.00)
Switch Lights ($100.00)
Wiring to Rear Galley for Lights ($50.00)
Cabinet Mod #5 - Divider Top Shelf o Galley ($75.00)
Cabinet Mod #3 - 24" Deep Galley ($250.00)
Cabinet Doors w/Latches ($100.00)
Folding Front Shelf ($100.00)
21 Gallon Water Tank w/Steel Skid Plate ($150.00)
Shurflo 12v Water Pump w/Electrical Wiring & Switch and Plumbing including Fill Port & Spray Port ($250.00)
Ecotemp L5 Hot Water Heater in Side Mounted Pelican Case w/Plano Case for all Hoses and Fittings ($300.00)
Rhino Rack XTray Large Roof Basket ($400.00)
Rhino Rack Batwing Awning - RH Mount ($700.00)
Rhino Rack Sunseeker 2.5m Awning - LH Mount ($310.00)
2 Rotopax 2-Gallon Water Cans w/mounting plate, mount, and extension ($190.00)
Queen Size Folding Mattress ($150.00)
Water Resistant Blackout Curtains ($100.00)
Seagrass Area Rug ($50.00)
Clip-on Folding Side Table ($120.00)
120v Ceramic Heater ($20.00)
Upgraded Safety Chains to 7,500lb Coiled Cables ($25.00)
Wheel Chocks
The only thing you’ll need to use this is a sleeping bag, and your cooler/kitchen gear.
More photos here: https://photos.app.goo.gl/j5qk2RpZABH1dz6h2
Not in any huge hurry to sell as it isn't really costing me that much so no low-ball offers. If you are wanting to buy it, you'll have to meet me at the credit union in Idaho Falls, ID to deal with the remainder of the loan I have left on it.
Asking $17,000 for a lightly used, ready to roll, off-road camper trailer without the year or more wait to have it built.
I live in the Tetons. The roads are way too icy/too much snow to even want to drive a trailer anywhere around here. Aside from that, it's not insulated for winter camping. I'd say it's definitely more of a three season camper. But, I have used it in the fall with temps down into the teens. I've run a Mr. Buddy for a few minutes every few hours to knock the chill down and I was fine for a week at a time. I guess it depends on what winters look like where you live though?
4Runner19
In the pictures I do not see a pelican case with water heater/ hose to spray dose your trailer have this things? I am interested
It does have a water heater in a Pelican case. It was added just this summer. It's in at least one of the later pics in the album.
Limeyboy999
Is your hiker still for sale?[/
7 Pin Wire Harness
Front Rack
Manual Roof Vent
Deluxe Cabinets
Black Trim ($50.00)
Roof Rack ($175.00)
Wheel Chocks
Limeyboy999
7 Pin Wire Harness
Front Rack
Manual Roof Vent
Deluxe Cabinets
Black Trim ($50.00)
Roof Rack ($175.00)
Wheel Chocks
Limeyboy999
Hi ...I was actually talking to these guys about building one. I have money in hand and would be willing to make this happen tomorrow if need be. My name is Paul and my number is+16505209369. Text me if you are interested. I’m even willing to go a bit over if need be. I’m not one to play games so let me know if you are interested
Messaged you.
eclipse179
