SOLD: 2018 Outdoors RV Creek Side 21RBS - Lakewood, CA
wesel123
Not a supper "Overland" style trailer, but it makes an amazing basecamp that you can bring down forest service roads. Set up a basecamp for a week or more, you'll run out of food before water and power!!! Our Family is growing therefore the need to sell our much loved 21 RBS, we will be upgrading to a larger Outdoors RV. It’s a 2018 model bought new in March of 2019 and have used it about 20 nights. Very clean in and out all systems run as they should. Full service done on water-heater two months ago (anode rid and heater element replaced). No rips or tears in roof, slide and all rubber gaskets lubed on each use, no cracks to roof sealant. Waxed less then three weeks ago by mobile detailer. The Power Wagon tows it with out a hitch (no pun intended).
Upgraded to 2 ea. 6 volt batteries, and changed the tires to BF Goodrich KO2’s. Added backup camera (remote screen in cab). Finally changed out the mattress to residential Sealy mattress (factory mattress leaves much to be desired).
Has factory options:
Mountain Storage System ( 2” receiver rated at 250 and Toy Lok)
12v Heat Pad for Fresh Water Tank
Dual Maxx Air Vents (Over bed and in bath)
Off Grid Solar Package (170 Watt Panel)
Off road suspension upgrade
SPECIFICATIONS:
Full Feature Dry Weight - Lbs.5520
Exterior Length (approx. hitch to back of ladder) 24'10"
Fresh Water Capacity (approx. gal).80
Water Heater Capacity (approx. gal).6
Heavy Duty 5 Lug Axles (lbs)4000(2)
Climate Designed Furnace25K
Exterior Height 11'3" w/AC
Interior Height 6'11"
LPG Capacity (approx. pounds).60
Grey Water Tank (approx. gallons)40
Black Water Tank (approx. gallons).40
Net Carrying Capacity.2730
Dry Hitch Weight (approx. Lbs.).660
Maximum Trailer Weight - Lbs8250
Equilizer hitch NOT included, we need it for out next trailer.
FiscAnd
