CObuilt
2018 Ram Promaster 2500 HR 159
126,000 miles
This van is built on the reliable and versatile front wheel drive Ram Promaster Platform. High end appliances and durable finishes make the interior of the van a refined and usable space. With 3 ways to charge the 300 amp hour lithium battery bank, power is never in short supply while bluetooth battery monitoring and intelligent Webasto air heating allow you to monitor and adjust critical systems from your phone. A Nature's Head composting toilet eliminates the need for a black water tank, and a tankless propane water heater supplies on demand hot water for showers. The reliable two burner propane stove is space efficient and easy to use while the two Maxxfan Deluxe fans create safe and comfortable air circulation for cooking and temperature regulation. The flush mounted, external, gray water tank and drains are protected by heating pads that make Four Season living a breeze. A stainless steel 12 volt fridge with separate freezer compartment and matching sink basin round out the kitchen. A swivel seat in the cockpit expands the living space and a 6 inch memory foam bamboo mattress provides a cozy bunk. The garage has ski and snowboard storage, two heavy duty 58" drawers, and three feet of vertical space as well as easy access to the fresh water refill. Five overhead cabinets provide ample storage for clothing, dry goods, and dishes. New WeatherTech floor mats and durable cloth seat covers help protect the cockpit.
This van has performed reliably as a full time home on wheels and has many miles ahead of it. The windshield is cracked and some body panels do show imperfections but the function of the van and living space are totally unaffected.
Electrical:
300 amp hour Lithium Iron Phosphate battery bank
525 watts solar
2000 watt inverter/charger
40 amp DC/DC alternator charger
60 amp Solar Charge Controller
Renogy M1 Smart Home Power Monitor
Appliances:
2 MaxxFan 7500 Deluxe with remote/thermostat/intake/exhaust
Webasto Evo 40 Gasoline Heater with Smartemp 3.0 bluetooth control (automatic altitude adjustment)
Nature's Head Composting Toilet
Excel Tankless Propane Water Heater
Greystone 2 Burner Propane Stove
Stainless Everchill 12v Fridge/Freezer
Seaflo water pump
Stainless Sink with Oversized Spray Head
28 Gallon Fresh Water Tank
26 Gallon Grey Water Tank *All external plumbing is protected by tank heaters for year-round use
6" Full size memory foam mattress
Insulation:
3m Thinsulate
Low-E Closed Cell Foam
1.5" Closed Cell Foam Subfloor
Seams taped
Storage:
5 overhead cabinets
Two drawer garage *larger drawer 500lb capacity/smaller drawer 250lb capacity
165cm Ski/Snowboard Storage
2" Hitch Receiver for rack style accessories
Extruded Aluminum Roof Rack With Additional Space for accessories
Finishes:
Stainless steel
Aromatic Cedar Paneling
Durable and Water Proof Rubber Floor
Included Accessories:
Insulated Four Season Window Covers
100ft Drinking Water Fill Hose
2 Freshwater inline filters
10ft Grey Water Drain Hose
Extendable Snow/Ice Brush
