SOLD--2018 Turtleback Adventure Trail, loaded with all options. $11,000. Located in NH
firnadlinh75
This thing is a beast. I'm looking to upgrade. 2018 Turtleback Adventure Trail with every option available for that model. MSRP was 19,000 new. I've had this out 5 times and it turns heads! You just don't see these back east. Made right here in the USA in Phoenix, AZ. The tent on this thing easily unfolds and you can completely enclose the awning section for a total of over 200 sq ft of live-able space. I even upgraded the mattress to an 8" thick gel memory foam mattress.
*TURTLEBACK ADVENTURE TRAIL BUILD PACKAGE.
*ADVENTURE / GETAWAY 3,500 LB AXLE 5X5 UPGRADE 3,500 LB RATED FLEX-RIDE RUBBER TORSION AXLE SYSTEM W/3,500 LB SPRINGS (5 X 5 HUBS).
*ADVENTURE / GETAWAY 10 INCH ELECTRIC BRAKES KIT (3500 LB AXLE
ONLY).
10 " ELECTRIC DRUM BRAKES (SELF-ADJUSTING) INCLUDES BREAKAWAY SAFETY SWITCH (3,500 LB AXLE ONLY).
*ADVENTURE / GETAWAY SINGLE BATTERY ELECTRICAL SYSTEM GXL 125° C AUTOMOTIVE WIRING, BLUE SEA MARINE-GRADE COMPONENTS, SINGLE DEKA GROUP 24 AGM DEEP CYCLE BATTERY, BATTERY BOX, BLUE SEA 6 CIRCUIT FUSE BLOCK, BLUE SEA SINGLE BATTERY
DISCONNECT SWITCH, 6 AMP HEAVY DUTY BATTERY CHARGER (SHORE POWER).
*ADVENTURE / GETAWAY LIGHTING KIT.
*ADVENTURE LIGHT KIT INCLUDING NOSE BOX, STORAGE BOX, AND REAR ACTIVITY QTY RATE AMOUNT AREA PUSHBUTTON LED LIGHTING.
*ADVENTURE / GETAWAY EXTERIOR CHARGE PORT12V SOCKET AND DUAL USB CHARGE PORTS INSTALLED IN EXTERIOR NOSE BOX SURFACE.
*ADVENTURE / GETAWAY PRIMARY PROPANE TANK 11 LB PANCAKE TYPE TANK WITH STAINLESS STEEL BRACKET AND STRAP.
*ADVENTURE / GETAWAY REAR KITCHEN REAR SLIDE OUT KITCHEN BALTIC BIRCH WITH SOLID MAPLE TOP ATWOOD DUAL BURNER STOVE. DOMETIC SINK WITH FAUCET.
*ADVENTURE / GETAWAY WATER SYSTEM. 21 GALLON BPH FREE FOOD GRADE WATER TANK WITH 12V ELECTRIC PUMP.
*ADVENTURE / GETAWAY TAILGATE WITH SPARE MOUNT SINGLE SWING OUT SPARE TIRE HOLDER WITH 2 PLATES FOR ROTOPAX FUEL KITS, TWO-POSITION LOCKING PIN, RATED FOR 125 LBS.
*OZ TRAIL OUTER RIDGE VENTURER FEATURING NEARLY 200 SQ FT OF FULLY EN-CLOSABLE LIVING SPACE WHEN COMBINED WITH INCLUDED SUNROOM. HIGH DENSITY FOAM QUEEN
SIZE BED. GAS STRUT ASSISTED UNDER-BED STORAGE ACCESS DOOR. GAS STRUT ASSISTED TENT MOUNT FOR FULL STORAGE ACCESS.
*REAR STABILIZER JACK TURTLEBACK REAR STABILIZER JACK SYSTEM
*SAFETY SYSTEMS TRAILER BREAK-AWAY BRAKE ACTIVATION SWITCH, LED YELLOW AND RED SIDE MARKER LIGHTS. LED BRAKE LIGHTS, SIGNAL LIGHTS, AND RUNNING LIGHTS. INTEGRATED REVERSE LIGHTS.
ADJUSTABLE REAR STABILIZER (REQUIRED FOR DISCONNECTED HITCH USE). DUAL TOWING SAFETY CHAINS.
*NOSE JACK 2,000 LB SWING AWAY TONGUE JACK.
*7-PIN TRAILER CONNECTION. INCLUDES CHARGE LINE, BRAKE
*ACTIVITY QTY RATE AMOUNT CONTROLLER LINE, RUNNING LIGHTS, SIGNAL LIGHTS, AND REVERSE LIGHTS.
*STANDARD COLOR POWDER COATING
*ADVENTURE / GETAWAY CHASSIS WELDED 2 X 3 GALVANIZED TUBE STEEL CHASSIS
*RECEIVER HITCHES FRONT AND REAR 2 INCH RECEIVER HITCHES
*TURTLEBACK ADVENTURE / GETAWAY TRAIL BOX KIT TURTLEBACK ADVENTURE 11-GAUGE ALUMINUM MAIN BOX WITH ALUMINUM NOSE BOX AND REAR DOOR
**TURTLEBACK ADVENTURE TRAIL FULLY OPTIONED ADD-ON PACKAGE ADVENTURE TRAIL FULLY OPTIONED ADD-ON PACKAGE INCLUDES:
*ADVENTURE / GETAWAY DUAL BATTERY ELECTRICAL SYSTEM GXL 125° C AUTOMOTIVE WIRING,
BLUE SEA MARINE-GRADE COMPONENTS, DUAL DEKA GROUP 24 AGM DEEP CYCLE BATTERY, BATTERY BOXES, BLUE SEA 6 CIRCUIT FUSE BLOCK, BLUE SEA DUAL BATTERY DISCONNECT SWITCH, 6 AMP HEAVY DUTY BATTERY CHARGER (SHORE POWER)
2000 WATT PURE SINE WAVE INVERTER WITH BLUE SEA 150 AMP BREAKER.
*KITCHEN CHARGE PORTS 12V SOCKET AND DUAL USB CHARGE PORTS INSTALLED NEXT TO SLIDE OUT KITCHEN.
*ZAMP 15 AMP SOLAR CONTROLLER WITH BATTERY MONITOR AND SAE WEATHERPROOF PANEL CONNECTOR IN NOSE BOX.
*ADVENTURE / GETAWAY KITCHEN APPLIANCE UPGRADE.
*ADVENTURE PARTNER STOVE UPGRADE (ON TOP OF KITCHEN UPGRADE)
*ADVENTURE / GETAWAY COMPOSITE KITCHEN UPGRADE UPGRADES KITCHEN TO MARINE
GRADE HIGH DENSITY POLYMER MATERIAL. WATERPROOF AND UV STABLE THIS MATERIAL WILL LAST A LIFETIME.
*15 INCH PRO COMP STEEL WHEEL WITH BFG KO2 31X10.5/R15 TIRE
*ACCESSORY PROPANE TANK ACCESSORY PROPANE TANK WITH STAINLESS BRACKET
*ADVENTURE / GETAWAY CLEAR COAT CLEAR COAT POWDER COATING FOR
METALLIC COLOR OR ADDED DURABILITY & ENHANCED FINISH
*ROTOPAX DELUXE PACK MOUNT
*ROTOPAX 2 GALLON GAS PACK
skrillah
Been following this for awhile. Looks perfect for my family of 4. Timing w COVID and everything has had me gun shy...
I’m in Indianapolis.
Subourbon
very interested and considering a road trip from Texas
Why are you wanting to upgrade? Have you used solar panels with this setup?
Houie
