SOLD 2020 Northstar 850SC Pop-Up Truck Camper REDUCED PRICE $25,500 OBO
Gunn It
Lightly used 2020 Northstar 850SC Pop Up Camper $25,500 OBO
I've added 470 watts solar, 400 AMP Hr Lithium Battery( Ampere Time), 3000 Watt Renogy Inverter , RecPro 9.5 Air Conditioner, Happy Jac Wireless Jacks, Toklift Glosteps. Camper has a GMC backup camera which allows full function of newer chevy and GMC surround camera systems. I'm also including Torklift Tie downs w/ Fast Gun Buckles This all exceeds $8,000 in added options that I added, not including the $1000's in factory options . This camper is better than new and save >$10,000. Camper was built Oct 2020.
This camper also has the more desirable Dometic 12 volt compressor refrigerator. With the Sub Zero insulation package, this pop up camper is ready for on, or off the grid camping. Everything works perfectly including all zippers.
Located in Marble Canyon, Arizona. Has been stored indoors when not in use.
From NorthStar:
This Northstar Pop-Up 850SC truck camper will easily fit on short (6'4" to 6'10") or a long bed (8') truck. This model features a U-shaped dinette where you can enjoy your meals at or transform into an extra sleeping space. Stepping inside the camper, to the right there is a shower and cassette toilet for your convenience so you have no need to use public facilities. In the front, there is a queen bed with hamper storage around it and storage below it, plus extra storage next to the Dometic refrigerator and even a wardrobe in the rear next to the Dometic glass top two-burner stove.
In every Northstar Pop-Up, you will find a truck camper that is ready to hit the roads whenever you are! Each model features a kitchen full of amenities you will need to create your best meals including a Dometic 3.7 cu. ft. three-way refrigerator to keep your leftovers and perishables fresh. These campers were built so you can travel anytime of the year and still stay warm with the 12,000 BTU auto ignition furnace with a digital thermostat, as well as the hand fitted block foam insulation and insulated floors. You will enjoy the LED lighting not only throughout the inside, but also outside with the patio lights. The 6" gel memory/high density foam mattress will help give you a good night's rest so that you can be ready for any adventure!
Sleeps 3 Length 15 ft
Ext Width 7 ft Int Height 6 ft 8 in
Exterior Color WHITE Dry Weight 1785 lbs
Fresh Water Capacity 30 gals Grey Water Capacity 13 gals
Black Water Capacity 5 gals Furnace BTU 12000 btu
Available Beds Queen Refrigerator Type Three Way
Refrigerator Size 3.7 cu ft Cooktop Burners 2
Floor Length 8 ft 6 in Center of Gravity Front 32 in
LP Tank Capacity 20 lbs Water Heater Type Auto Ignition
Number of LP Tanks 1 Body Style Pop-Up
Shower Type Wet/Bath Shower Electrical Service 30 amp
Plenty of Storage
3.7 Cu. Ft. Refrigerator
Patio Lights
LED Lighting
20230808_085039.jpg20230908_121418.jpg20230908_102624.jpg20230908_121525.jpg20230908_102653.jpg20230908_121040.jpg
Wolfbox
