Sold 78 Bronco
Dirt Rider
Best overland foundation you can buy, 9 inch rear, dana 44 front, fresh brakes, new u joints, T18 granny low tranny, NP205 TC, 351M, new front BFG tires. Too many projects, sitting for the last year, dash apart to fix speedo. $2500 OBO.
Dirt Rider
No, the sun had done a number on it. Was planning to do a full cage, with canvas to replace it. They are not hard to find if you want one. It has been sitting a few years now and half the dash is apart to fix the speedo, so it looks a bit rough, it is a project, more than someting that is ready to roll.
Dirt Rider
Ask and you shall...As you can see it is rough from sitting out side, want to make sure anyone knows what they are buying, and no surprises
Dirt Rider
Rear seat is in it, could use a recover. Engine was running 2 years ago when parked. Down on power, thinking the CAT may be plugged up, its the original, as is everything else. Took dash apart to fix the speedo that went bad and remove the old after market AC assy. Have not had the time or interest to finish the project.
guapstyle
