SOLD Denver, CO: 1996 E350 4x4 Wheeled Coach Ambulance - 7.3 - AUTO - 142k Miles - Clean CO Title - $32,500
N.Y.X.
Based on some new life events, I have decided to sell a few of my projects. This has been a great rig, utilized both on and off road. I have tested the features and lived out of this rig for 10+ days at a time. It’s not the perfect build, but could be perfect for someone. The biggest thing for me was that I can only stand straight up on the first step of the side entry door. So if you are over 6 foot, this would be something to consider.
Price is $32,500 and is considered to be “or best reasonable offer” and only TRADE: Newer Truck 4x4. Would prefer something built up a bit and less than 60k miles. My trade value is $38,000 and I am not looking to add any money on top. Either straight up trade or your truck plus cash.
1996 Ford E350 4x4 Wheeled Coach Ambulance - AUTO - 142k Miles - Clean CO Title - 1FDKE30F6THA91566
  • 7.3 liter Power Stroke Turbo Diesel w/ TS Performance 6 Position Chip.
  • Professional 4x4 conversion completed by Salem & Kroger w/ F350 4x4 parts.
  • Floor 4x4 Shifter w/ Warn locking hubs up front.
  • All original sirens and emergency lights removed so it is legal to own and operate.
  • Rough Ambulance body dimensions: 70” Interior Height; 139” exterior length - 94” wide.
  • All of the compartments/doors have functioning locks.
Maintenance in the last 10k miles:
  • Turbo – Original Turbo Failure did not contaminate engine oil
  • Vacuum pump
  • Fuel pump
  • Serpentine belt (spare included)
  • Injection pressure sensor
  • Cam position sensor
  • Transmission flushed & Mag-Hytec high capacity pan added
  • Oil Change/Diesel Additive/Greased all driveline zerk fittings
  • (1) x New Battery Hood - (3) x New Deep Cycle Battery Compartment
  • Alignment
  • Custom Cold Air Intake w/ K&N Filter & Pre Filter
Kitchen/Bath:
  • Dometic Dual Burner Propane Stove w/ glass top
  • Dometic Strainer/Sink Combo w/ Pull Down Faucet
  • GASLAND Tankless Propane Water Heater 10L – 2.64GPM
  • SEAFLO Self Priming Pump 3.0GPM – 45PSI w/ Pre Pressurized Accumulator .75L – 125PSI
  • 40 Gal fresh water tank
  • RCA 3.2 cu.ft. Mini Fridge
  • KICKASS Instant Ensuite Camping Shower Tent w/ High Pressure Head & Bamboo Mat
  • Medicine Cabinet, Interior Mirror, Knife/Utensil Wall Magnet, Paper Towel Holder
  • Large removable table that stows under bed w/ plenty of butcher block surfaces
  • Pot/Pan/Dish/Glass Storage
Queen Bed/Sofa:
  • Queen sized platform bed with 12V – 30” lift system, can be used as a large single bed as well
  • Lucid 2” Queen Memory Topper goes over a Double Sized memory foam mattress, split in two
  • Utilizes Lower Sofa Backrest as Headboard
  • Privacy Shade, Storage/Phone Holders, Footboard Storage, Laundry Net
  • Sofa Bench is 72”L x 24” x 3” – Backs are 24”L and 43”L x 24” x 3”
  • Bench has a hinged top with storage underneath
Solar/12V/Electronics/Etc.:
  • (4) Rich Solar 100W Roof Mounted Solar Panels (400W) – 40 Amp Circuit Breakers
  • Renogy Advanced Rover Li 40 Amp 12V DC Input MPPT Solar Controller w/ Bluetooth and LCD screen
  • (3) Super Start Deep Cycle Batteries 105 AH each (315 AH) w/ NOCO GENIUS10
  • MaaxAir Fan with Auto Temp setting, Floor Fan x 2 and a Hot Water Heater Vent Fan
  • Wireless Backup Camera and Front Dash Cam
  • Complete On Board Air System w/ Air Horns and Rear Air Bags
  • Interior Lights changed with dimmable LED lights, Upgraded Switch Panels and Outlets
  • LED Smart TV w/ Wall Mounted Full Motion Stand
  • Kenwood Bluetooth Radio w/ Upgraded Pioneer Cab Speakers
  • 5KW Diesel Heater
  • DOT LED Headlights, Light Bar and Driving Lights, Exterior Lighting Upgraded to LED’s
  • Engine Block Heater
Other:
  • Ostrich Wing Awning Grey, Passenger Side Mount w/ LED Lights
  • Camco Olympian Wave-3 Catalytic Heater
  • Rear Hitch Installed, Front Hitch has not been installed yet
  • (2) Floor MTB Fork Mounts w/ (2) Front Wheel Holders under the Bed Frame
  • Front and Side Entry Door Screens
  • Sliding between cab door, (2) 12” x 21” Windows
  • Dynamat sound deadening mat was added on cab and ambulance body floor
  • Passenger side, rear wall and part of the box was reinsulated w/ 2 layers of 3M Thinsulate thermal/acoustic
  • PERGO Laminate Flooring, Floor and Wall Anchor Points
The Bad:
  • AC system has a leak, new compression line included.
  • I wasn’t able to paint the exterior, but does come with a gallon of “Duck Drab” color.
  • The inverter is old and I do not believe it to be very efficient and a lot of wiring could still be removed.
  • Dimming Switch and Remote for Ceiling Lights have not been wired.
  • I feel like the interior cab fan is under powered and could be improved for winter driving.
  • It definitely needs a brake controller if you plan to tow heavy.
Please note that not everything that is pictured is included in the sale; i.e. generator, toilet, pots/pans, etc. I am willing to negotiate a complete package. TY!
mbobhat
