*SOLD* FS TN: 2006 Dodge Ram 2500 Megacab
SixLug
Sold. Sad day.
Last year of the Cummins 5.9. Laramie Package. 165,000 miles. Clean title in hand.
$24,000.00 (or more unlikely, will trade for a 5th Gen 4Runner 4WD only)
Truck is a daily driver, so miles will go up and it will get a bit dirty.
I am the third owner and purchased the truck at 115,000 miles. From what I was told, the first owner was an older guy that occasionally towed a 5th wheel camper. He sold it to the next guy at about 80k miles I think. Before I bought it I took it to Tomlin Diesel in Franklin for a pre-purchase inspection and it got a clean bill of health so I bought it.
I have never personally towed anything but a 5x8 utility trailer. 95% of its life with me has been driving 80 interstate miles every day for work (400 miles a week) so mostly highway for the last 50,000 miles. It is hard to find this truck in mostly stock form and not abused, with decent miles (less than 12,000 a year), in this condition. It isn’t a perfect show truck, but it is in very good shape overall.
It had an Anarchy Diesel tune on it when I got it, which I removed. It came with a Smarty Jr. also so I put the Smarty on it and tuned it to the “factory tune”, but left the oversize tire calibration on it. I also put the stock intake back on it at one point, but I’m pretty sure I lost about 1 mpg so I put the S&B intake back on. But it has been on a factory tune since I bought it. It has a 4” turbo-back exhaust. I also removed the two-piece steel driveshaft and installed a one-piece aluminum driveshaft from a later model. A/C has been completely replaced except for one hardline under the intake; all other lines, compressor, condenser, accumulator, liquid line with orifice, evaporator, and hi/low line into compressor are new. The outside air blend door was replaced with an aluminum blend door from Blend Door USA. All other HVAC doors were cleaned and new seals were installed. A/C blows ice cold, front and rear. No dash cracks. I have always used Rotella T5 oil, Donaldson ELF7349 oil filters, and Baldwin PF7977 fuel filters. Look this stuff up, but it’s the good stuff.
Comes with an ARE contractor shell with matching locks for the truck key, 5 Dodge factory steel wheels (one with a spare tire), Anarchy tuner, Smarty Jr. tuner, factory carpet mats, and Weather Tech floor mats.
The following is the list of work I have done to the truck.
-115,500 Oil & fuel filter change
-120,302 New BFG A/T 285/75R17 tires
-121,460 Oil & fuel filter change
-126,283 Fuel filter change
-129,016 oil change, rotated tires; fronts straight back, rears crossed to the front
-131,610 Fuel Filter change
-131,966 adjusted valves, IN .010” / EX .025”
-132,350 installed new block heater and cord
-133,393 Discount Tire balanced tires
-134,480 new one-piece aluminum rear driveshaft (no more carrier bearing)
-134,600 rotated tires
-135,858 oil, oil filter, fuel filter change
-140,175 A/C system overhaul. New compressor, condenser, accumulator, liquid line with orifice, evaporator, and hi/low line into compressor.
-140,874 fuel filter, Rotated tires
-141,560 two new front BFG AT tires due to bad runout on one, moved one to spare spot
-143,381 oil / filter
-146,439 fuel filter
-150,808 tires rotated (fronts straight back, rears crossed)
-151,023 oil, oil filter, fuel filter change w 12 qts T5 15W40
-156,556 fuel filter changed
-158,709 oil, oil filter change w 11.5 qts T5 15W40
-158,957 new front brakes and rotors, rotated tires. Fronts strait back rears crossed front
- 162,693 fuel filter changed
I have a lot of pictures, but here are a few to chew on...
Idahopapa
Do you have any pictures with the shell? Reading through the maintenance list is there a reason why the fuel filter has been changed so periodically?
SixLug
Fuel filter is changed roughly every 5000 miles because it seems that is a well accepted interval to keep the system clean. They are cheap, and injectors / fuel system maintenance is not.
verdesard0g
Search and Rescue first responder
wow! clean truck, that's about what I paid for my 06 crewcab with 80k 10 years ago.These trucks hold their value!
SANelson
