SOLD: Kelderman Air Suspension Rear Sway Bar 4500 5500
Brad_UT
Rear sway bar from Kelderman airbag suspension kit for 2020 Ram 5500. Designed for 19500 GVWR platform like an ambulance or fire department brush truck. May fit other trucks or your custom project. Dimensions shown. Comes with polyurethane brackets and everything in pictures. New, never used. Came with my kit, but didn't use it.
If you see this ad, it's still for sale. Cash only. Located near Ogden, UT just north of Salt Lake City. Will not ship. Must pick up. $100.
IMG_4025.JPEGIMG_4026.JPEGIMG_4027.JPEGIMG_4028.JPEGIMG_4029.JPEGIMG_4030.JPEGIMG_4031.JPEGIMG_4032.JPEGIMG_4033.JPEG
n0arp
Would it reuse the mounts for the factory bar, or does Kelderman ship a custom bracket for it? If it uses the factory mount I'm interested, and will be passing through UT in the next couple months.
Brad_UT
The blue/gold colored polyurethane mounts in the above pictures bolt to the stock mounting locations on the axle.
You'll have to come up with a way to attach the ends of the sway bar up to the frame, as I used the frame side brackets Kelderman supplied. All of that stuff is easily fabbed up. I may still have the connecting links Kelderman supplied. You're welcome to them. Give me a shout when you're in town. I'm north of SLC about 30 min.
flipstick
