Rad Coast
I’m a custom teardrop trailer builder in southern California and I built a trailer to be a rental but I don’t have time to deal with renting a trailer right now so I’m putting it up for sale. I pretty much went all out on this build geared towards a Toyota tow vehicle keeping it light and wheel matching but maxing it out on options. I built it to be the best!
If you have any questions or want to see other builds or build photos message me @ rad.trailers@gmail
-5x9 1400 lbs dry weight (7 wide 13.5 long and 6.5 overall)
-Fully insulated 1.5 inches R-Tech in the walls roof and hatch 2 inches in floor
-Welded steel frame
-Anodized aluminum skin 0.063 on centre with black anodized 0.040 on sides
-Full aluminum skid plate
-oversized steel rock guarded fenders
-Custom roof rack legs and Rhino vortex cross bars
-All exposed frame is rock guarded
-Max coupler articulating hitch
-Rear 2” receiver
-3 5000 HD tube jacks
-Full Baltic birch construction no softwood 2x2’s
-Timbren 1 tone HD axel less suspension with 4 inch lift (23 inches of clearance)
-Toyota TRD Pro rims (purchased from Toyota) with Toyo open county 265/70 R17
-10 inch electric brakes
-7 blade trailer plug with breakaway switch
-30x36 inch double doors with sliding screened windows (4 inches wider than most trailers Timberleaf, Escapod.. etc.)
-10 speed maxx fan with remote, rain sensor and thermostat
-Stargazer window
-Upgraded interior cabinets with pull out table
-All led lighting with built in dimmers
-Upgraded galley with locking cooler slide with 12 volt power for electric fringe/cooler
-6 inch full size memory foam mattress
-200 watts of solar
-30 amp mppt charge controller with upper galley monitoring system
-Progressive Dynamics charger/converter shore power 30amp service
-100 amp hour lithium battery
-6 USB chargers and 3 12 volt power points
-2 GFI protected outlets
-Welded steel frame
-Rear 2” receiver
-Stargazer window
-200 watts of solar
