[SOLD] REDUCED 2021 Taxa Overland Cricket $21,000
Girdlebug
=============SOLD, NOT AVAILABLE==================
2021 Taxa Overland Cricket $27,000 -- reduced to $21,000
Located in Atlanta, GA
Only taken out 4 times, started a business and too busy to take it more.
This is the Overland version without any of the regular trailer's sagging axle problems. Timbren 3500lbs axle-less suspension with a 4" lift.
2 20lb propane tanks on the tongue to power the heater, AC on the side. Lock-N'Roll articulating hitch for 360 degree 3 axis movement, all terrain car tires (not trailer tires).
Lists anywhere from $37-44k new. Only been in the rain once, garage-stored indoors all the time. I siliconed all the roof rivets as soon as I got it, not a drop of moisture inside.
Imperfections:
-Door ding (pictured) from when the door was opened into the corner of the garage
-Some rub marks below the stove where the Dometic handle rubbed against the wooden cabinet (also pictured)
Girdlebug
The pic I uploaded is from the other angle. There's a square tubing cross brace that goes the width of the trailer. If you zoom in on my pic you'll see the same rubber suspension.
bdpkauai
