Rudyesparza83
2012 Livin Lite CampLite 16 bhb
2500LBS Dry Weight
Hesperia CA
$18500
All aluminum construction ( frame, structural, wall, one piece aluminum roof, aluminum built beds, cabinets etc)
Dometic European pop out windows
Dometic 3 way fridge (propane, ac/dc)
Dometic Porcelain Toilete
MaxxAir Rain and Temperature sensor fans
Awning material replaced
Torsion Dual Axles with Electric braking
Dual propane setup
New Eaz Lift Scissor Stabalizers
Renogy AGM 100 Amp Hour Battery
Only issue is the Aesthetics of the paint.
These are considered the only true “generational travel trailer”. There is no wood or steel inside or outside the trailer ( throw your magnets away). It is a masterpiece, if you appreciate aluminum construction. I am considering having it repainted, but that will cause a change in price.
Please let me know if you should have any questions.
2500LBS Dry Weight
Hesperia CA
$18500
Dual propane setup
