ExpoMike
Well, in anticapation of our upcoming Death Valley trip, I wanted to get a couple things done to the Kamparoo I have been putting off. Okay, in reality I am in the middle a another huge project that has been going on a year, tying up the garage. I made room to get the welder out.
I have wanted to remove the spare tire and propane tank and mount a pair of AT gas can holders and mount the spare with a crank up system like a truck has. I picked up a cable style crank up system so when up, nothing hangs down. It proved to be a little more work to get that to fit, since it needed to be higher than the tire so you can access the crank fitting with a jack handle. Overall everything worked well but I need to put some stop points for the tire so it will snug up tight and not move around.
At this point I am sore and tired (man I am getting old) but happy. I'll get things finished up this week. Here are some pics.
Original configuration
Stuff getting removed
New bars welded on, awaiting holes drilled and paint
Mocked up and holes drilled for mounting
Finished up, forget pics of painted bars
Just need to get some locks now and the can mounts are done. :wings:
