Airmapper
Inactive Member
So I need a CB setup, bad. I need to have it for an upcoming trip with other rigs, and I just lost my decent location with a 4ft Firestik on top the truck due to the RTT.
I have a horrible selection of options, so I came up with what you see in the image (there should be an image) below. It's a base loaded whip, fender mounted to a NMO base. I fabbed the mount from stainless sheet metal. I have an identical setup on the opposing side for my 2M/70cm rig, which works wonderfully, but that antenna is much shorter.
It's way too close to my FM (music) radio antenna, so I'll likely need to remove that when it's in use. I have a NMO cap so I'll probably only use the CB antenna when in convoy with other trucks, but still I think it's going to be a nuisance bouncing around, but it shouldn't snag on trees.
It needs to be tuned, so before I start chopping on it, is this setup even viable? I only need it for convoy use.
Thanks in advance.![Smile :) :)](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
Thanks in advance.
