Explorerinil
What about ABS brakes, stability control and possibly traction control issues with a different sized tire on your 19 ram?
Cannot agree, do some research with your local vehicle regulations, I'll bet you will find a law saying you cannot do it.A 37 will not fit in the spare location on a Ram.
It’s really not dangerous to run a different tire.
Like I said I wouldn’t do it for long or at high speed, but differentials are literally designed to spin axle shafts at different speeds. Why do you think your tires don’t chirp around corners? The inside tire will always spin at a slower speed than the outside tire.
The number of people that don’t get that is astounding.
Don’t run it on the rear, or in 4 wheel drive and you’ll be fine.
Considering there is no law that says you can not run a donut spare doubt you will find much in that regard. If there is it wont be enforced.Cannot agree, do some research with your local vehicle regulations, I'll bet you will find a law saying you cannot do it.
Why did you ask the question if your mind was made up?
Yes like I mentioned, the ABS system, vehicle stability control... it will throw codes.With modern vehicle, you run the risk of screwing up the signals to the PCM .
