Spray in Bedliner ???
dosxxtaco
I just took out the factory plastic liner and want a sprayed in one.
Which company do you guys think will hold up with this AZ heat!!
Line-x or ?:)
CYi5
Line-X gets my vote. Be sure to get the extra UV coating to prevent any future fading.
BogusBlake
2006 Expedition Trophy Champion
Line-X.
I have that and I parked every day in AZ the sun for the past three years and it holds up great. No fading or deterioration at all.
Mc Taco
American Adventurist
X3 on the Line-X, and the UV protection for fading. Mine has been in the Inland So Cal sun for a year now and is holding up quite well.
taco chaser
Supporting Sponsor
I'd go with Rhino lining , most the LineX jobs I've seen chip, peel, and it goe's on looking like sand paper, sorry guy's.
tacollie
Glamper
Either line-x or rhino will hold up great as long as the bed is striped right. My buddies does a ton of line-x and said as long as they prep it right it hold up great. I had a rhino in my other taco and it held up great. If it is preped incorrectly it will oxidize through. That holds true with any finish though.
SLOwag
I have Rhino with a shell on top so I can't vouch for the longevity under the sun....But, the Rhino is a little stickier than the Line-X jobs I've seen. This can be either good or bad depending on what results you want from the product.
For instance, loading lumber or other products that I want to slide into my bed isn't as easy with Rhino but gear and other stuff doesn't slide around as much. My truck isn't a work truck but the Rhino has never scuffed or developed divots with the use and abuse I give it. HTH
SAR_Squid79
Another vote for Line-X. I have had mine in 3 extreme Northern Illinois winters, as well as the heat of Summer in Moab. I couldn't ask for better than this Line-X.
Desertdude
Line-X in AZ for over two years still looks like new - the whole key to any of these spray in liners are prep. I wiped the whole bed clean with Acetone before bringing the Tacoma in for the spray - the person was meticulous with the wire tape so all the edges are clean - he removed any screws in the tailgate and on the inside bed hooks - when replaced looks lika a factory job.
I am happy with it :)
RHINO
ditto with DD,,, real clean lines and all the screws and hooks were removed for the application, it was done at universal in mesa or chandler or somewhere with a 480 area code.
robert
My last Taco was Rhino lined. I had a camper shell on it most of the time so the UV wasn't a real issue. I was really impressed with it.
02tacotoy
BogusBlake said:
Line-X.
what can you expect to pay for a line-x job??
Desertdude
IIRC I paid for an over the bed, plus over the tailgate by about 4 " - $325.00 or so (by a line-x dealer in CA)
