cruiseroutfit said:A standard coil compressor simply won't work well on the front Tacoma struts (coil & shocks). Which OME coils are you using? You can either have someone pre-assemble them for you using a strut compressor or a press (with attachments), or compress them using the A-arm.
Here are some threads with more info:
http://expeditionportal.com/forum/showthread.php?t=6462&highlight=strut
http://expeditionportal.com/forum/showthread.php?t=643&highlight=strut
HOYTUSA said:Kurt - they are 881's. I like the simplicity of the jack method but I will still need a "strut compressor"to take the old struts off, correct?
HOYTUSA said:my bad! I knew I could get them off the truck without the compressor but I will still need it to disassemble the old strut to get the old plate/mount off. So I can reuse the old plate/mount on the new OME strut.
unless someone can recomend a place to pick up a new top plate/mount for the OME strut?
