Spring spacers in the front?
factoryKITTED
I’m currently running ARB/OME springs & shocks on my G55. The bottom of the front fender flare sits about a solid inch lower than the rear. Do you see any issue with running a 30mm spacer in the front to level the truck out? The truck is not weighted down, no winch or heavy bumpers.
Thanks!
Well since I’m getting no response I’ve had some time to think about it....
I know that I can run the 30mm spring spacers on top of the OME spring but the real question I have is how much will the steering geometry, caster etc be affected? Keep in mind that I’m happy with the rear height and do not plan on using a spacer in the rear. My goal is to level the truck out.
MOLLYmaz
