started my 4x4 conversion and I have some questions
svo_jon
I plan to install a 3/4 ton d44 front axle in my E150 using coil springs, radius arms and a track bar. My first question is; does anyone know what I should set my caster to? I plan to lift the van around 4".
Thanks
Jonathan
Toolman
Look at UJOR videos. That will pretty much tell you everything you neeeeeeeeeeeeeeeeeeeeeeeeeeed to know.
svo_jon
Thanks Toolman.
Can anyone tell me what the steering knuckles on a dana front axle are made of? Cast steel? Just wandering what I should use to weld my brackets to them with.
Thanks
Jonathan
referring to the C-s welded on the axle: From my research and someone whom I trust I would say cast steel, but a spark test will tell for sure. Most of them are weld-able using standard methods. Many people have cut and rotated then welded using standard process without cracking. The word on the street for my Dana 44 (79 bronco high pinion) is they are cast steel and weld-able without a nickel rod. Your mileage may vary.
Jeffh555
I narrowed and turned the early 70s Dana 44 under my rock crawler using standard mig wire and CO2/Argon mix. No pre heat or post heat, just burned them on. I've been wheeling it for about 8 years with no problems. Well, plenty of problems :eek:, just none related to the welding of the knuckles.
Sfreeman
