Sterling 10.5 into E350 pinyon angle
MadChad
First step is to get a sterling 10.5 rear axle into the E350 and was wondering if I could use the current spring pad angle, or does this require some refinements.
I'm sure I could get the answer with a single phone call but thought I'd use the fourm instead.
The plan is to have it with the stock springs for now and then later add the 6" lift springs. I will be using UJOINT spring pad.
Jody Treadway
If you are using a standard non-CV (non-double cardan) driveshaft, you'll want the pinion angle about 2* below the transfer case output shaft angle. This puts the output shaft and the pinion shaft nearly parallel with one another.
If you are using a a CV/ double cardan jointed shaft, you'll want the pinion rotated up, pointing about 2* below the t case output shaft.
Make sense?
MadChad
Thank you for the reply Jody,
Now if I plan to use an nv271 but don't have it yet will the angle change from the current angle of the tail shaft(up or down)?The driveshaft is a single so it will be 2* below.
ujoint
Supporting Sponsor
It's gonna be tricky since you're doing the axle 1st. I would set it the same as the factory axle and run a CV once the t-case is installed. This way e-thing is good while you're still 2wd. The only downfall to what you're doing is having to modify the driveshaft twice.
MadChad
Oops big time laymen here, the drive shaft will need to be modified to accept the sterling?Also is there any advantage running standard over cv.
Thank you for the reply.
Wood Kutter
Does the driveshaft actually need to be shortened for him to keep 2wd for now ? They do make Hybrid U-joints that are 2 different sizes. 1 pair of spindles is 1 size/ dia. and the other pair is a different size/ dia.
MadChad
It might be wise for me to wait and do all at once. Just thought I'd get the sterling in before we take our Yellowstone trip.
nely
Not to take over the thread......But
For those who want the info for later, like i will be needing,
What is the proper pinion angle for the sterling rearend after the 4x4 has been installed?
Wood Kutter
@Ujoint, do you know what I mean by the Hybrid U-joints ? The driveshaft end could be like a 1310 & the flange could be a 1350. The Hybrid is like the 2 different Ujoints put together. I have used them before when changing rear ends without modifying the driveshaft.
MadChad
WK that would be cool. I'd carry a spare because I don't think auto zone would have one on the shelf. Great idea.
ujoint
Supporting Sponsor
I set the pinion angle the same as stock for the 4 & 6" kits. Anything higher & I use the formula that Jody posted.
Yep, I've seen them. This may work if he has a flange yoke that will fit the Sterling. Worst case here is a new ujoint & flange at the rear axle.
Bobah
