Hey Folks,
I'm new to the site and have an awesome van for sale. I hope this is the appropriate place to post.
It is with much sadness that I must announce the selling of Trouble: my SAS Astro. 16,500 obo.
1998 Chevy Astro with V8, 4x4 Conversion and camper setup that is CA STREET LEGAL, SMOG LEGAL and registered. It HAS NOT been beat up.
Cargo, sleeping, offroad ability and towing capacity make this an ideal vehicle for any outdoors person.
It is the product of 5 years of evolution and testing. I've spent a lot of time and money to get this rig ready to sell.
Pinion angles are good, Caster, Camber and Toe are all good. Sway is minimal. Highway speeds are no problem. Suspension and stance provide excellent handling for a vehicle in this class. Drives way better than a Sportsmobile on and offroad! It will go anywhere you want and can still be parallel parked in the city. Excellent turning radius. NO BUMP STEER. (Interior pics make seat look discolored, but they are clean and comfy).
Here is the list of modifications. I would be happy to talk more via phone. Reasonable offers only please. This is an extremely well equipped SUV and well worth the cost. It has TWICE the asking price invested in it.
Motor: 150,000 mi. Runs strong. Compression is good. Regular oil changes.
1999 5.7L Chevy 350 from K1500 Suburban. Professionally installed by GM tech, wired and calibrated properly. Speedometer is accurate. Dual Flex-a-Lite 11" electric fans with high capacity radiator core.
Transmission: 3,000mi.
Professionally rebuilt 4L60E with shift kit. Automatic.
Auxiliary trans cooler.
Transfer case:
NP231C manual shift.
Custom drive lines
Running Gear: ratio 4:10
Front: Dana 44: TruTrac posi
Rear: Ford 9inch: TracLoc posi
Overall stance length is 4inches longer than stock; 2in. each front/rear.
Suspension:
Front- Fox 2.0 remote reservoir coilover shocks (re-valved for vehicle weight) with Eibach 500lb springs. (new)
Rear- New Fox remote reservoir adjustable shock. Heavy duty add a leafs.
Steering Stabilizer: Fox gas. New
Breaks:
Rear- New Drums, shoes and rebuild kit.
Front -Caliper upgrade late 70's Thunderbird (still single piston but larger). New pads and rotors.
New Delco Hydroboost.
Tires: 200mi.
New BFG AT 32x11.5x15: siped.
Exhaust:
High flow with 2x catalytic converters matching the donor vehicle's lay out and 100% CA smog legal.
Steering:
AGR custom gear box
Bullet Proof Steering Company: tie rod, drag link, trackbar: all with heavy duty heim joints.
Custom pitman arm.
Custom Offroad Tube bumpers with tow receiver and swing out tire carrier. Impressive approach and escape angles.
Camper setup:
Seat/bed. Sleeps 2 if ottoman is in place.
Westfalia Kitchen insert with upgraded 12v fridge. Has sink, 2 burner stove, cabinet.
124w solar panel.
Starting and house battery are relatively new and deep cycle. Battery selector switch.
2 vent fans- 6in. and 11in.
Swivel passenger seat: normal seat height.
15gal potable water tank.
Excellent sound system including 10" subwoofer and amp.
Call Gabe: 303-807-3594
Transfer case:
Custom drive lines
Suspension:
Breaks:
Tires: 200mi.
Exhaust:
Steering:
AGR custom gear box
Custom pitman arm.
Camper setup:
124w solar panel.
