I know most people with truck campers have installed airbags on the truck with campers. But anyone here have installed Sumo spring on their truck with campers? if so how do they compare with airbags?
I've got a 2500 Ram 4x4 with Carli Long Travel airbags. The bags are about 10 yrs old now and showing their age. I'm getting some chafing. I still get more sway then I'd like with my 2300# Northstar popup. I have the stock Hellwig Swaybar. The rear is about 1.5-2.0" higher than stock. Will your severe duty system work with this mild lift? The camper stays on 24/7. I would imagine the Timbrens would have to come off unladen but it's a simple job.We have our SES system designed to keep your truck level while towing as well as give you a smooth comfortable ride. The biggest difference from airbags is that it is maintenance free and doesn't require anything more than a wrench to install. Here is a link to check out our system - Timbren SES
If you have any questions let us know!
Not sure if the review is "unbiased" but on the site Truckcamper adventure I just found a review for SumoSprings. As I mentioned before they don't list a product for my vintage of truck, so I'll probably go with Timbrens when I have the time and cash.
I do have one question for the Timbren rep that replied above, I've read some forum posts that the SES can be quite jarring when the bumpstop is not fully engaged, for instance when driving with an unloaded truck bed or if you don't get the gap measurement right and your loaded truck bed enounters a sharp bump at speed.
My issues with my setup is the truck camper just engages the top overload leaf, has a tendancy to sway side to side when off-road and mild porposising when driving on road at speed, can the timbren system mitigate some or all of this, or is my tired old truck due for a whole new suspension system.
Thank you. I carry a popup camper on my back 24/7.The Timbren SES system is designed to remain on the vehicle at all times whether the rear is loaded or not loaded. Our system will work with the lifted rear you referenced as well as mitigating or eliminating the sway you are experiencing with your popup trailer. This system can replace your bags and can last beyond the ten years you have seen with your current airbag setup! If you have any other questions please feel free to reach out to us.
So that bottom stack of springs is now history? That's a lot of springs for a popup although they can be nearly as heavy as a hardsided camper.I'm running a carli 2.5 pintop suspension, with sumosprings replacing the bumpstop, helwig hd swaybar and deaver full leaf pack on f250 with popup camper. View attachment 610766Softer ride than previous oem with supersprings
Yes, the oem/superspings combo replaced by the Deavers progressive springs, that were custom built to handle weight of the f250 with popup camper.So that bottom stack of springs is now history? That's a lot of springs for a popup although they can be nearly as heavy as a hardsided camper.
I've been up to their shop. I was salivating. They started out doing covered wagons and buggy's. Good deal bud! Did they do the install?Yes, the oem/superspings combo replaced by the Deavers progressive springs, that were custom built to handle weight of the f250 with popup camper.
